[Qgis-developer] qgis pre-refresh rendering ?
Sandro Santilli
strk at keybit.net
Sat Dec 13 08:40:10 PST 2014
On Sat, Dec 13, 2014 at 10:40:44PM +0700, Martin Dobias wrote:
> The Qt framework uses pos() and boundingRect() to understand where the
> items are located in the scene (QGraphicsScene). These are all screen
> coordinates - one can tell from the use of QPointF instead of QgsPoint
> (always used for map / layer coordinates).
> The rect() and setRect() is just our added convenience functionality in
> QgsMapCanvasItem. The idea was that you just use setRect() to specify the
> item's position+size in map coordinates - and the pos() and boundingRect()
> will be set according to that. In addition, calls to updatePosition() from
> map canvas make sure that pos() and boundingRect() are kept in sync with
> changes to the canvas.
The problem with that, as you can see, is that it is assumed that
a single rectangle can fully express a map configuration, but that's
only true when there's no rotation.
This lack of information makes it impossible for updatePosition to
keep a rotated map position/size in sync with canvas changes.
> Some canvas items use that functionality (e.g. QgsRubberBand or
> QgsMapCanvasMap) and don't worry about the screen coordinates. For some
> items this default behavior is not useful, so they do not use setRect() and
> provide their own implementation of updatePosition() and boundingRect().
> For example QgsVertexMarker, which is centered on a map coordinate, but its
> bounding box is independent from map coordinates / scale.
Maybe the object passed via setRect (via QgsMapCanvasMap::setContent)
could possibly be syntetized as a rectangle having the map coordinate
corresponding to device position (0,0) as its upper-left corner and
width and height being the output device width and height scaled by the
current map resolution. But we'd still be in the "workaround" side.
--strk;
() ASCII ribbon campaign -- Keep it simple !
/\ http://strk.keybit.net/rants/ascii_mails.txt
