[Qgis-developer] Make error - QGIS Latest (2.6.0)
Ian Turton ijturton at gmail.com
Mon Dec 15 07:37:42 PST 2014
Was a solution found for this error? I'm trying to build 2.6.1 and it's
falling foul of the same error that Mark talks about here, but it's beyond
my limited python skills to work out how to fix it.
Cheers
Ian
On Mon Nov 03 2014 at 10:22:28 AM Mark Wynter <mark at dimensionaledge.com>
wrote:
> Thanks Jurgen  Yep, that was the problem.   Built with latest QScintilla2
> from source.   Successfully installed QGIS 2.7.0 (git master repository)
> on CentOS65.
> However, I get a ‘processing' error message on starting QGIS2.7.0.  Didn’t
> have this problem two days ago with QGIS2.4.0.
> Couldn't load plugin 'processing' from ['/usr/local/share/qgis/python',
> '/home/mark/.qgis2/python', '/home/mark/.qgis2/python/plugins',
> '/usr/local/share/qgis/python/plugins', '/usr/lib64/python26.zip',
> '/usr/lib64/python2.6', '/usr/lib64/python2.6/plat-linux2',
> '/usr/lib64/python2.6/lib-tk', '/usr/lib64/python2.6/lib-old',
> '/usr/lib64/python2.6/lib-dynload', '/usr/lib64/python2.6/site-packages',
> '/usr/lib64/python2.6/site-packages/PIL',
> '/usr/lib64/python2.6/site-packages/gst-0.10',
> '/usr/lib64/python2.6/site-packages/gtk-2.0',
> '/usr/lib64/python2.6/site-packages/webkit-1.0',
> '/usr/lib64/python2.6/site-packages/wx-2.8-gtk2-unicode',
> '/usr/lib/python2.6/site-packages',
> '/usr/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg-info',
> '/usr/local/share/qgis/python/plugins/fTools/tools']
> Traceback (most recent call last):
>   File "/usr/local/share/qgis/python/qgis/utils.py", line 185, in
> loadPlugin
>     __import__(packageName)
>   File "/usr/local/share/qgis/python/qgis/utils.py", line 460, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "/usr/local/share/qgis/python/plugins/processing/__init__.py", line
> 29, in
>     from processing.tools.general import *
>   File "/usr/local/share/qgis/python/plugins/processing/tools/general.py",
> line 29, in
>     from processing.core.Processing import Processing
>   File
> "/usr/local/share/qgis/python/plugins/processing/core/Processing.py", line
> 47, in
>     from processing.modeler.ModelerAlgorithmProvider import \
>   File
> "/usr/local/share/qgis/python/plugins/processing/modeler/ModelerAlgorithmProvider.py",
> line 35, in
>     from processing.modeler.ModelerAlgorithm import ModelerAlgorithm
>   File
> "/usr/local/share/qgis/python/plugins/processing/modeler/ModelerAlgorithm.py",
> line 100
>     return {k:v for k,v in self.__dict__.iteritems() if  not
> k.startswith("_")}
> SyntaxError: invalid syntax
> Python version:
> 2.6.6 (r266:84292, Jan 22 2014, 09:42:36)
> [GCC 4.4.7 20120313 (Red Hat 4.4.7-4)]
> QGIS version:
> 2.7.0-Master Master, exported
> Python path: ['/usr/local/share/qgis/python', u'/home/mark/.qgis2/python',
> u'/home/mark/.qgis2/python/plugins',
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141215/a9c8fff1/attachment-0001.html>
