[Qgis-developer] QGIS Android crash on startup
Paolo Cavallini cavallini at faunalia.it
Thu Dec 18 23:02:36 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
On my Nexus 5, running Android 5.0, latest build from
http://qgis.org/downloads/android/ always crashes on startup, see
logcat below.
Should I open a ticket?
All the best.
E/AndroidRuntime( 6073): FATAL EXCEPTION: main
E/AndroidRuntime( 6073): Process: org.qgis.qgis, PID: 6073
E/AndroidRuntime( 6073): java.lang.UnsatisfiedLinkError: JNI_ERR
returned from JNI_OnLoad in "/data/app/org.qgis.qgis-1/lib/arm/libqgis.so"
E/AndroidRuntime( 6073): at
java.lang.Runtime.loadLibrary(Runtime.java:371)
E/AndroidRuntime( 6073): at java.lang.System.loadLibrary(System.java:989)
org.qtproject.qt5.android.bindings.QtActivity.loadApplication(QtActivity.java:255)
org.qtproject.qt5.android.bindings.QtActivity.access$400(QtActivity.java:99)
org.qtproject.qt5.android.bindings.QtActivity$3$1$1.run(QtActivity.java:314)
android.os.Handler.handleCallback(Handler.java:739)
android.os.Handler.dispatchMessage(Handler.java:95)
E/AndroidRuntime( 6073): at android.os.Looper.loop(Looper.java:135)
android.app.ActivityThread.main(ActivityThread.java:5221)
E/AndroidRuntime( 6073): at java.lang.reflect.Method.invoke(Native Method)
java.lang.reflect.Method.invoke(Method.java:372)
com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:899)
com.android.internal.os.ZygoteInit.main(ZygoteInit.java:694)
E/ActivityManager(  741): Invalid thumbnail dimensions: 576x576
Completo:
D/OpenGLRenderer( 6073): Render dirty regions requested: true
D/Atlas   ( 6073): Validating map...
I/MinistroService( 5529): refreshLibraries took 56 ms
I/MinistroService( 5529): checkModulesImpl took 2 ms
I/Adreno-EGL( 6073): <qeglDrvAPI_eglInitialize:410>: QUALCOMM Build:
10/24/14, 167c270, I68fa98814b
I/OpenGLRenderer( 6073): Initialized EGL, version 1.4
D/OpenGLRenderer( 6073): Enabling debug mode 0
I/Qt      ( 6073): qt start
I/Qt      ( 6073): Sensors start
I/QtPositioning( 6073): Positioning start
D/AndroidRuntime( 6073): Shutting down VM
W/ActivityManager(  741):   Force finishing activity
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity
I/WindowManager(  741): Screen frozen for +1s199ms due to
Window{1a443fd6 u0
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity}
I/WindowManager(  741): Screenshot max retries 4 of Token{28a56480
ActivityRecord{3979cd03 u0
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity t2087 f}}
appWin=Window{1a443fd6 u0
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity} drawState=1
I/OpenGLRenderer(  741): Initialized EGL, version 1.4
W/ActivityManager(  741): Activity pause timeout for
V/ActivityManager(  741): Display changed displayId=0
I/ActivityManager(  741): Config changes=480 {1.0 222mcc99mnc it_IT
ldltr sw360dp w360dp h567dp 480dpi nrml port finger -keyb/v/h -nav/h
s.132}
I/InputReader(  741): Reconfiguring input devices.  changes=0x00000004
I/InputReader(  741): Device reconfigured: id=4, name='touch_dev',
size 1080x1920, orientation 0, mode 1, display id 0
I/ActivityManager(  741): Process com.google.android.apps.plus (pid
5249) has died
I/ActivityManager(  741): Process com.google.android.calendar (pid
5910) has died
I/ActivityManager(  741): Process com.android.providers.calendar (pid
5865) has died
I/ActivityManager(  741): Process com.google.android.partnersetup (pid
6022) has died
I/ActivityManager(  741): Process org.kde.necessitas.ministro (pid
5529) has died
I/WindowState(  741): WIN DEATH: Window{d644fa9 u0
com.google.android.GoogleCamera/com.android.camera.CameraLauncher}
I/WindowState(  741): WIN DEATH: Window{1a443fd6 u0
I/Choreographer(  887): Skipped 34 frames!  The application may be
doing too much work on its main thread.
D/audio_hw_primary(  184): disable_audio_route: reset and update mixer
path: low-latency-playback
D/audio_hw_primary(  184): disable_snd_device: snd_device(2: speaker)
I/ActivityManager(  741): Process com.google.android.GoogleCamera (pid
27826) has died
I/WindowManager(  741): Screen frozen for +1s36ms due to
Window{2d8a0096 u0 com.android.systemui.ImageWallpaper}
I/ActivityManager(  741): Process org.qgis.qgis (pid 6073) has died
W/WindowManager(  741): Failed looking up window
W/WindowManager(  741): java.lang.IllegalArgumentException: Requested
window android.view.ViewRootImpl$W at 31708167 does not exist
W/WindowManager(  741): at
com.android.server.wm.WindowManagerService.windowForClientLocked(WindowManagerService.java:8412)
com.android.server.wm.WindowManagerService.windowForClientLocked(WindowManagerService.java:8403)
com.android.server.wm.WindowManagerService.removeWindow(WindowManagerService.java:2558)
com.android.server.wm.Session.remove(Session.java:186)
android.view.ViewRootImpl.dispatchDetachedFromWindow(ViewRootImpl.java:2920)
android.view.ViewRootImpl.doDie(ViewRootImpl.java:5390)
android.view.ViewRootImpl$ViewRootHandler.handleMessage(ViewRootImpl.java:3223)
android.os.Handler.dispatchMessage(Handler.java:102)
W/WindowManager(  741): at android.os.Looper.loop(Looper.java:135)
android.os.HandlerThread.run(HandlerThread.java:61)
com.android.server.ServiceThread.run(ServiceThread.java:46)
W/InputMethodManagerService(  741): Window already focused, ignoring
focus gain of:
com.android.internal.view.IInputMethodClient$Stub$Proxy at fef0410
attribute=null, token = android.os.BinderProxy at 3d29753d
D/ConnectivityService(  741): updateNetworkScore for NetworkAgentInfo
[WIFI () - 161] to 56
D/ConnectivityService(  741): rematching NetworkAgentInfo [WIFI () - 161]
D/ConnectivityService(  741): Network NetworkAgentInfo [WIFI () - 161]
was already satisfying request 1. No change.
D/ConnectivityService(  741): notifyType AVAILABLE for
D/ConnectivityManager.CallbackHandler(  887): CM callback handler got
msg 524290
D/TaskPersister(  741): removeObsoleteFile: deleting file=2085_task.xml
D/TaskPersister(  741): removeObsoleteFile: deleting file=2087_task.xml
I/ActivityManager(  741): Start proc com.google.android.apps.plus for
service
com.google.android.apps.plus/com.google.android.apps.moviemaker.service.PluggedInAnalyzerService:
pid=6197 uid=10063 gids={50063, 9997, 3003, 3002, 1028, 1015}
abi=armeabi-v7a
W/ResourcesManager( 6197): Asset path
'/system/framework/com.google.android.maps.jar' does not exist or
contains no resources.
I/art     (  741): Explicit concurrent mark sweep GC freed 201324(8MB)
AllocSpace objects, 12(2MB) LOS objects, 26% free, 44MB/60MB, paused
1.658ms total 210.596ms
I/Adreno-EGL( 6197): <qeglDrvAPI_eglInitialize:410>: QUALCOMM Build:
I/GLSActivity( 5724): [ad] getting account id
I/GLSUser ( 5724): [p] Fetched account id for
paolo.cavallini at gmail.com : 113285634206889120929
D/WifiService(  741): acquireWifiLockLocked: WifiLock{NlpWifiLock
type=2 binder=android.os.BinderProxy at 265bcdb1}
[WIFI () - 161] to 60
msg 524290
I/art     ( 6062): Explicit concurrent mark sweep GC freed 101688(5MB)
AllocSpace objects, 2(32KB) LOS objects, 39% free, 22MB/38MB, paused
860us total 66.273ms
D/WifiService(  741): releaseWifiLockLocked: WifiLock{NlpWifiLock
I/GCoreUlr( 6062): Successfully inserted location
I/GCoreUlr( 6062): Not calling LocationReporter, hasMoved: false,
elapsed millis: 331046, request: Stationary(3600000)
I/GAV2    ( 6197): Thread[GAThread,5,main]: No campaign data found.
msg 524290
E/WifiStateMachine(  741): WifiStateMachine CMD_START_SCAN source -2
txSuccessRate=4,47 rxSuccessRate=3,99
targetRoamBSSID=a4:b1:e9:c8:69:7e RSSI=-78
E/WifiStateMachine(  741): WifiStateMachine starting scan for
"Telecom-64129150"WPA_PSK with 2452
I/wpa_supplicant(  852): wlan0: CTRL-EVENT-SCAN-STARTED
txSuccessRate=0,07 rxSuccessRate=0,06
targetRoamBSSID=a4:b1:e9:c8:69:7e RSSI=-79
I/art     ( 1955): Note: end time exceeds epoch:
txSuccessRate=0,30 rxSuccessRate=0,24
targetRoamBSSID=a4:b1:e9:c8:69:7e RSSI=-81
10007 txSuccessRate=0,15 rxSuccessRate=0,12
targetRoamBSSID=a4:b1:e9:c8:69:7e RSSI=-82
W/PropertyValuesHolder( 1266): Method setBrightness() with type int
not found on target class class us
W/PropertyValuesHolder( 1266): Method getBrightness() with type null
I/ActivityManager(  741): START u0 {act=android.intent.action.MAIN
cat=[android.intent.category.LAUNCHER] flg=0x10200000
cmp=org.qgis.qgis/org.qgis.QgisActivity (has extras)} from uid 10019
on display 0
D/audio_hw_primary(  184): out_set_parameters: enter: usecase(1:
low-latency-playback) kvpairs: routing=2
D/audio_hw_primary(  184): select_devices: out_snd_device(2: speaker)
in_snd_device(0: none)
D/msm8974_platform(  184): platform_send_audio_calibration: sending
audio calibration for snd_device(2) acdb_id(15)
D/audio_hw_primary(  184): enable_snd_device: snd_device(2: speaker)
D/audio_hw_primary(  184): enable_audio_route: apply and update mixer
I/ActivityManager(  741): Start proc org.qgis.qgis for activity
org.qgis.qgis/org.qgis.QgisActivity: pid=6385 uid=10065 gids={50065,
9997, 3003, 1028, 1015} abi=armeabi-v7a
I/art     ( 6385): Late-enabling -Xcheck:jni
ldltr sw360dp w598dp h335dp 480dpi nrml land finger -keyb/v/h -nav/h
s.133}
size 1080x1920, orientation 1, mode 1, display id 0
I/FirstRun JAVA( 6385): last
git_rev:cfef6a8bfb03cac23e598d116310e90193db047f
I/FirstRun JAVA( 6385): this
I/FirstRun JAVA( 6385): not first run, forwarding to QGIS
{cmp=org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity} from
uid 10065 on display 0
W/ContextImpl( 6385): Implicit intents with startService are not safe:
Intent { act=org.kde.necessitas.ministro.IMinistro }
android.content.ContextWrapper.bindService:538
org.qtproject.qt5.android.bindings.QtActivity.startApp:654
org.qtproject.qt5.android.bindings.QtActivity.onCreate:880
I/ActivityManager(  741): Start proc org.kde.necessitas.ministro for
service org.kde.necessitas.ministro/.MinistroService: pid=6420
uid=10138 gids={50138, 9997, 3003} abi=armeabi-v7a
D/OpenGLRenderer( 6385): Render dirty regions requested: true
D/Atlas   ( 6385): Validating map...
I/Adreno-EGL( 6385): <qeglDrvAPI_eglInitialize:410>: QUALCOMM Build:
I/OpenGLRenderer( 6385): Initialized EGL, version 1.4
D/OpenGLRenderer( 6385): Enabling debug mode 0
W/IInputConnectionWrapper( 1266): showStatusIcon on inactive
InputConnection
I/MinistroService( 6420): refreshLibraries took 58 ms
elapsed millis: 395432, request: Stationary(3600000)
I/MinistroService( 6420): checkModulesImpl took 12 ms
I/ActivityManager(  741): Displayed
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity: +321ms
(total +2m38s369ms)
I/WindowManager(  741): Screen frozen for +490ms due to
Window{109840b4 u0 StatusBar}
I/Qt      ( 6385): qt start
I/Qt      ( 6385): Sensors start
I/QtPositioning( 6385): Positioning start
D/AndroidRuntime( 6385): Shutting down VM
E/AndroidRuntime( 6385): FATAL EXCEPTION: main
E/AndroidRuntime( 6385): Process: org.qgis.qgis, PID: 6385
E/AndroidRuntime( 6385): java.lang.UnsatisfiedLinkError: JNI_ERR
E/AndroidRuntime( 6385): at
E/AndroidRuntime( 6385): at java.lang.System.loadLibrary(System.java:989)
E/AndroidRuntime( 6385): at android.os.Looper.loop(Looper.java:135)
E/AndroidRuntime( 6385): at java.lang.reflect.Method.invoke(Native Method)
ActivityRecord{354df891 u0
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity t2088 f}
s.134}
I/art     (  741): Explicit concurrent mark sweep GC freed 143345(6MB)
AllocSpace objects, 9(209KB) LOS objects, 25% free, 47MB/63MB, paused
1.303ms total 130.321ms
I/WindowManager(  741): Screen frozen for +595ms due to
I/Process ( 6385): Sending signal. PID: 6385 SIG: 9
I/WindowState(  741): WIN DEATH: Window{3b2f99fc u0
I/ActivityManager(  741): Process org.qgis.qgis (pid 6385) has died
window android.view.ViewRootImpl$W at 38edb759 does not exist
I/art     (  741): Explicit concurrent mark sweep GC freed 72690(3MB)
AllocSpace objects, 2(32KB) LOS objects, 26% free, 44MB/60MB, paused
1.459ms total 75.474ms
txSuccessRate=0,04 rxSuccessRate=0,28
targetRoamBSSID=a4:b1:e9:c8:69:7e RSSI=-80
on display 0
org.qgis.qgis/org.qgis.QgisActivity: pid=6529 uid=10065 gids={50065,
I/art     ( 6529): Late-enabling -Xcheck:jni
s.135}
I/FirstRun JAVA( 6529): last
I/FirstRun JAVA( 6529): this
I/FirstRun JAVA( 6529): not first run, forwarding to QGIS
W/ContextImpl( 6529): Implicit intents with startService are not safe:
D/OpenGLRenderer( 6529): Render dirty regions requested: true
D/Atlas   ( 6529): Validating map...
I/MinistroService( 6420): refreshLibraries took 43 ms
I/MinistroService( 6420): checkModulesImpl took 3 ms
I/Adreno-EGL( 6529): <qeglDrvAPI_eglInitialize:410>: QUALCOMM Build:
I/OpenGLRenderer( 6529): Initialized EGL, version 1.4
D/OpenGLRenderer( 6529): Enabling debug mode 0
I/Qt      ( 6529): qt start
I/Qt      ( 6529): Sensors start
I/QtPositioning( 6529): Positioning start
D/AndroidRuntime( 6529): Shutting down VM
E/AndroidRuntime( 6529): FATAL EXCEPTION: main
E/AndroidRuntime( 6529): Process: org.qgis.qgis, PID: 6529
E/AndroidRuntime( 6529): java.lang.UnsatisfiedLinkError: JNI_ERR
E/AndroidRuntime( 6529): at
E/AndroidRuntime( 6529): at java.lang.System.loadLibrary(System.java:989)
E/AndroidRuntime( 6529): at android.os.Looper.loop(Looper.java:135)
E/AndroidRuntime( 6529): at java.lang.reflect.Method.invoke(Native Method)
I/WindowManager(  741): Screen frozen for +633ms due to Window{6d0ed9a
u0 org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity}
I/WindowManager(  741): Screenshot max retries 4 of Token{2e0d1324
ActivityRecord{35363fb7 u0
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity t2089 f}}
appWin=Window{6d0ed9a u0
s.136}
I/WindowManager(  741): Screen frozen for +399ms due to
D/TaskPersister(  741): removeObsoleteFile: deleting file=2088_task.xml
29648(1448KB) AllocSpace objects, 10(2MB) LOS objects, 27% free,
42MB/58MB, paused 1.420ms total 150.414ms
txSuccessRate=0,00 rxSuccessRate=0,00
W/ActivityManager(  741): Activity destroy timeout for
ActivityRecord{2e87ca3a u0 org.qgis.qgis/org.qgis.QgisActivity t2089 f}
window android.view.ViewRootImpl$W at 12317bf does not exist
[WIFI () - 161] to 55
msg 524290
D/TaskPersister(  741): removeObsoleteFile: deleting file=2089_task.xml
msg 524290
I/Process ( 6529): Sending signal. PID: 6529 SIG: 9
focus gain of:
com.android.internal.view.IInputMethodClient$Stub$Proxy at 3cc706ab
I/ActivityManager(  741): Process org.qgis.qgis (pid 6529) has died
on display 0
org.qgis.qgis/org.qgis.QgisActivity: pid=6666 uid=10065 gids={50065,
I/art     ( 6666): Late-enabling -Xcheck:jni
s.137}
I/FirstRun JAVA( 6666): last
I/FirstRun JAVA( 6666): this
I/FirstRun JAVA( 6666): not first run, forwarding to QGIS
I/UsageStatsService(  741): User[0] Flushing usage stats to disk
W/ContextImpl( 6666): Implicit intents with startService are not safe:
D/OpenGLRenderer( 6666): Render dirty regions requested: true
D/Atlas   ( 6666): Validating map...
I/MinistroService( 6420): refreshLibraries took 48 ms
I/MinistroService( 6420): checkModulesImpl took 1 ms
I/Adreno-EGL( 6666): <qeglDrvAPI_eglInitialize:410>: QUALCOMM Build:
I/OpenGLRenderer( 6666): Initialized EGL, version 1.4
D/OpenGLRenderer( 6666): Enabling debug mode 0
I/Qt      ( 6666): qt start
I/Qt      ( 6666): Sensors start
I/QtPositioning( 6666): Positioning start
D/AndroidRuntime( 6666): Shutting down VM
E/AndroidRuntime( 6666): FATAL EXCEPTION: main
E/AndroidRuntime( 6666): Process: org.qgis.qgis, PID: 6666
E/AndroidRuntime( 6666): java.lang.UnsatisfiedLinkError: JNI_ERR
E/AndroidRuntime( 6666): at
E/AndroidRuntime( 6666): at java.lang.System.loadLibrary(System.java:989)
E/AndroidRuntime( 6666): at android.os.Looper.loop(Looper.java:135)
E/AndroidRuntime( 6666): at java.lang.reflect.Method.invoke(Native Method)
I/WindowManager(  741): Screen frozen for +617ms due to
Window{2910cc26 u0
I/WindowManager(  741): Screenshot max retries 4 of Token{90ffa50
ActivityRecord{3e5cd813 u0
org.qgis.qgis/org.qtproject.qt5.android.bindings.QtActivity t2090 f}}
appWin=Window{2910cc26 u0
s.138}
I/WindowManager(  741): Screen frozen for +417ms due to
msg 524290
I/art     (  741): Explicit concurrent mark sweep GC freed 58648(2MB)
AllocSpace objects, 8(128KB) LOS objects, 27% free, 42MB/58MB, paused
1.458ms total 134.111ms
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iEYEARECAAYFAlSTzTUACgkQ/NedwLUzIr6o8gCgs64NUx4jdeNxxcYnvgmOgsmT
mA4AoIBgkgyMFA4no7z18xG2PX4yqiyH
=CdWN
-----END PGP SIGNATURE-----
