[Qgis-developer] Can qgis be started with python disabled ?
Martin Dobias wonder.sk at gmail.com
Sun Dec 21 06:12:49 PST 2014
On Wed, Dec 17, 2014 at 1:30 AM, Sandro Santilli <strk at keybit.net> wrote:
> Can I start qgis with no python support even if it is compiled in ?
> I'd use it to reduce load while running under valgrind...
> To the same extent, can it be started with no plugins from an environment
> variable or similar?
A bit more hard-core, but you can e.g. rename libqgispython.so to something
else - it is loaded on demand and if the load fails QGIS will just run
without python.
Cheers
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141221/5fc70a2b/attachment.html>
