[Qgis-developer] Problem inserting a new version of plugin
Geo DrinX geodrinx at gmail.com
Mon Dec 29 02:15:28 PST 2014
Great !    You have right !   I dropped all spaces around the "=" and it
works !!!
Thank you Werner !   And Happy New Year !!!!
Roberto
2014-12-29 11:07 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> Hi!
> I had a short look into my plugin and found
> experimental=True
> I am not sure but probably its the space in front and after the = sign?
> I guess it's worth a try ;)
> regards
> Werner
> On Mon, Dec 29, 2014 at 11:02 AM, Geo DrinX <geodrinx at gmail.com> wrote:
> > Hello,
> > I am trying to insert a new version of  "rasmover" plugin, but I had
> errors
> > from the page:
> >  http://plugins.qgis.org/plugins/rasmover/version/add/
> > This is the ZIP  that I am inserting:
> > https://github.com/geodrinx/rasmover/archive/master.zip
> > The error I receive is:
> > "There wer errors reading plugin package (please check also your plugin's
> > metadata).
> > The 'experimental' flag in the form does not match the 'experimental'
> flag
> > in the plugin package metadata' "
> > and then (also after set the experiemntal flag) I had:
> > "This field is required"
> > without other indication.
> > Could someone help me ?
> > Thank you
> > Roberto
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141229/55ec845a/attachment.html>
