[Qgis-developer] New feature: RFC saving style and ui in Spatialite
aperi2007 aperi2007 at gmail.com
Wed Feb 5 13:29:37 PST 2014
The 3MB size is the size of an empty DB spatialite .
A DB emty is 3MB size .
A DBspatialite with 1 single dataset of 10MB is
3MB +10MB = 13MB.
A DBspatialite with 3 dataset everyone of 10MB is
3MB + 10MB +10MB + 10MB = 33MB.
Also, AFAIK the goal of Luigi is storing in the spatialite the SLD
finalized to rendering the same dataset stored in the spatialite,
not to store SLD for general usage.
Regards,
Andrea.
On 05/02/2014 22:24, Etienne Tourigny wrote:
> Saving style as spatialite files would probably cause a significant
> file size overhead - don't all spatialite files take at least 3MB for
> the SRS tables?
> On Wed, Feb 5, 2014 at 10:18 AM, Gino Pirelli <luipir at gmail.com
> <mailto:luipir at gmail.com>> wrote:
>     Hi,
>     I'm developing a new feature to save SLD and ui in Spatialite
>     provider in the same way this function is available for postgres.
>     this function developed for Faunalia is funded by ARPA Piemonte
>     fork is available at:
>     https://github.com/luipir/QGIS/tree/spatialite-savestyle
>     and actual modification are localized in this
>     commit: f058bea1fe51116b8231eb5c1ca4faee485c38b2
>     there are some question about how to develop it and are related
>     how to manage XML in a sqlite/spatialite table.
>     this code derive by the postgres provider code where QML and UI
>     xmls are recorded in a XML column. XML is a postgres type. This
>     type is not available in SQlite but it's available in SL 4.1>
>     (called XmlBlob [1])
>     In this preliminary commit XML is saved in a text column, but
>     saving XML as a blog (blob type in sqlite or XmlBlob in SL) have
>     the advantage to avoid all encoding problems.
>     so the question is... sqlite blob or spatialite xmlbob?
>     Blob type can't allow XML parsing using SQL queries
>     XmlBlob allows this (using libxml2)
>     Blob type is sqlite native type
>     XmlBlob can be used only with SL 4.1>
>     My preference is to use native data type Blob. What's you opinion
>     about blob/ xmlblob or whatever
>     regards,
>     Luigi Pirelli (luigi.pirelli at faunalia.it
>     <mailto:luigi.pirelli at faunalia.it> - luipir at gmail.com
>     <mailto:luipir at gmail.com>)
>     [1]
>     https://www.gaia-gis.it/fossil/libspatialite/wiki?name=XmlBlob-intro
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140205/61ce4027/attachment.html>
