[Qgis-developer] Embedded group bug ?
kimaidou kimaidou at gmail.com
Wed Feb 19 00:57:14 PST 2014
Thanks Adreas for your prompt answer.
2014-02-19 9:47 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Michael,
> It is a known issue and Marco Hugentobler is working on it (hopefully
> still in time for 2.2).
Ok. thanks Marco.
> BTW: you will not be able to rearrange the order of individual layers if
> you embed a whole group - only the group at a whole.
Exactly. I just tried only because of the issue. I won't need it if groups
and layers are embedded correctly.
> But the order
> within the embedded group should be correct once the bug is fixed. If
> you want to reorder embedded groups or layers you will have to embed
> them individually several times.
This is what I did to avoid the bug after I discovered it. I recreated a
group and sub groups with individual embeded layers in them. Then I use
QGIS project templates to save this state and create new projects with the
same group.
Michael
> Andreas
> Am 19.02.2014 08:41, schrieb kimaidou:
> > Hi list,
> > Yesterday I played a little bit with the feature "Embed layers or
> groups".
> > I works well for single layers, but it seems to behave randomly for
> groups.
> > For example, embedding a group containing sub-groups and layers does not
> > produce the right result in my case : the group is imported, but only
> > contains the sub-group. All the layers from parent project origninally
> > contained in the group root are imported in the root of the legend in the
> > child project. Second problem : the layers are imported with reverse
> order
> > compared to their order in the parent project.
> > Espected behaviour :
> > * imported group
> > -- * sub-group
> > ---- * layer A
> > ---- * layer B
> > -- * layer 1
> > -- * layer 2
> > Actual "buggy" behaviour :
> > * layer 2
> > * layer 1
> > * imported group
> > -- * layer B
> > -- * layer A
> > And I cannot move the layers 1 and 2 afterwards in the "imported group"
> as
> > the embedded groups are read-only.
> > Has anyone seen this happen ?
> > I would be happy to report a bug in hub.qgis.org
> > Michael
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140219/bc0bd29d/attachment.html>
