[Qgis-developer] Embedded group bug ?
kimaidou kimaidou at gmail.com
Wed Feb 19 03:30:47 PST 2014
Ok
Thanks Marco for your work and help.
Michael
2014-02-19 10:44 GMT+01:00 Marco Hugentobler <
marco.hugentobler at sourcepole.ch>:
>  Hi Andreas and Michael
> Working on the embedded group bug right now btw.
> >For layers, there is the layerIsEmbeded method of the QgsProject class,
> but what about groups ?
> There is no such method for groups, because QgsProject does not know
> anything about groups. Only the legend knows about groups, and there is a
> C++ method QgsLegend::groupEmbedded, but without python bindings in the
> legend interface.
> Regards,
> Marco
> On 19.02.2014 10:07, kimaidou wrote:
>  Hi,
> Another question regarding the embeded groups. Is there any way to tell if
> a group is an embeded group with python bindings ? For layers, there is the
> layerIsEmbeded method of the QgsProject class, but what about groups ?
>  Cheers
>  Michael
> 2014-02-19 9:57 GMT+01:00 kimaidou <kimaidou at gmail.com>:
>> Thanks Adreas for your prompt answer.
>> 2014-02-19 9:47 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi Michael,
>>> It is a known issue and Marco Hugentobler is working on it (hopefully
>>> still in time for 2.2).
>>  Ok. thanks Marco.
>>> BTW: you will not be able to rearrange the order of individual layers if
>>> you embed a whole group - only the group at a whole.
>>  Exactly. I just tried only because of the issue. I won't need it if
>> groups and layers are embedded correctly.
>>> But the order
>>> within the embedded group should be correct once the bug is fixed. If
>>> you want to reorder embedded groups or layers you will have to embed
>>> them individually several times.
>>  This is what I did to avoid the bug after I discovered it. I recreated
>> a group and sub groups with individual embeded layers in them. Then I use
>> QGIS project templates to save this state and create new projects with the
>> same group.
>>  Michael
>>> Andreas
>>> Am 19.02.2014 08:41, schrieb kimaidou:
>>>  > Hi list,
>>> > Yesterday I played a little bit with the feature "Embed layers or
>>> groups".
>>> > I works well for single layers, but it seems to behave randomly for
>>> groups.
>>> > For example, embedding a group containing sub-groups and layers does
>>> not
>>> > produce the right result in my case : the group is imported, but only
>>> > contains the sub-group. All the layers from parent project origninally
>>> > contained in the group root are imported in the root of the legend in
>>> the
>>> > child project. Second problem : the layers are imported with reverse
>>> order
>>> > compared to their order in the parent project.
>>> > Espected behaviour :
>>> > * imported group
>>> > -- * sub-group
>>> > ---- * layer A
>>> > ---- * layer B
>>> > -- * layer 1
>>> > -- * layer 2
>>> > Actual "buggy" behaviour :
>>> > * layer 2
>>> > * layer 1
>>> > * imported group
>>> > -- * layer B
>>> > -- * layer A
>>> > And I cannot move the layers 1 and 2 afterwards in the "imported
>>> group" as
>>> > the embedded groups are read-only.
>>> > Has anyone seen this happen ?
>>> > I would be happy to report a bug in hub.qgis.org
>>> > Michael
>>>  > _______________________________________________
>>> > Qgis-developer mailing list
>>> > Qgis-developer at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140219/c1dff37c/attachment-0001.html>
