[Qgis-developer] Which compiler for a c++ QGIS custom app
    Jürgen E. Fischer
    jef at norbit.de
    Fri Feb 21 07:24:14 PST 2014
Hi Denis,
On Fri, 21. Feb 2014 at 15:20:19 +0100, Denis Rouzaud wrote:
> I have installed QGIS libs, Qt libs and minGW using osgeo4w installer
> (thanks to Nathan's advices).
mingw using the osgeo4w installer?  That might be there for GRASS.
But QGIS and Qt in OSGeo4W is built with Visual C++ not MinGW.  You can't use
OSGeo4W's Qt with MinGW.
> Does someone know which compiler to use? Can't I use one embedded in
> osgeo package?
> PS: I don't have visual studio installed, and I would like to avoid
> installing it.
Sorry, I didn't do that for years - should also be possible, but I suppose it
takes some work.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
