[Qgis-developer] Which compiler for a c++ QGIS custom app
Jürgen E. Fischer jef at norbit.de
Mon Feb 24 03:24:46 PST 2014
Hi Denis,
On Mon, 24. Feb 2014 at 12:10:53 +0100, Rouzaud Denis wrote:
> I installed Visual Studio Express 2013, and it seems the compiler given with
> (version 12.0) is not compliant with Qt libs from the osgeo package.
Right, if you want to use Qt from OSGeo4W you need to you the same compiler as
the one used to build Qt.    That is 2008 for 32bit and 2010 for 64bit.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
