[Qgis-developer] Datum transformations
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Feb 24 05:16:58 PST 2014
Hi Leyan
 >I struggled quite a lot with the interface of a very famous commercial
GIS on this issue, I believe there is a real possibility to do better
here ! I think it is essential to allow the >user to change the
transformation later easily, maybe somewhere linked from the CRS choice
? That's where I would go as a user.
He, he, I bet it is the same GIS :-)
 >I was also wondering how you see the relationship between CRS and
datum transformation. I use CRSs (all the Beijing54 CRS) which already
have a +towgs84 defined in their >definition, but several towgs84
coefficients are offered when loading the layer. It is confusing to have
to answer that, and if something else than the default coefficients is
chosen, >the result is incompatible with the proj4 definition. Should we
strip these CRS definitions of the towgs84 coefficients (which were only
meant for a small area initially, so are not >valid everywhere)?
Do you mean we should strip the towgs84 parameters from
tbl_srs.parameters or do you mean to deprecate/remove entries from
tbl_datum_transform?
 >Also, do you see a need to allow to define a custom datum
transformation, or do you think it is enough that user can create a
custom CRS with different towgs84 parameters?
It is possible to add new entries to tbl_datum_transform to create
custom datum transformations. Yes, it would be more convenient to have a
gui for that, even if I don't know how often it will be used. You might
judge it better since you obviously have to deal often with CRS issues.
Regards,
Marco
On 24.02.2014 13:35, Leyan wrote:
> On 02/24/2014 05:45 PM, Marco Hugentobler wrote:
>>> - GUI: have a tab in project properties where non-default datum
>>> transforms would be managed - instead of requiring the user to select
>>> the datum transform immediately when the layer was added (and without
>>> being able to change the decision later)
>> I don't have a strong opinion if it should be in project properties
>> or if the user should be asked immediately. The immediate selection
>> has been implemented following the behaviour of a commercial GIS.
>> However, the possibility to change it later easily does also sound
>> good to me.
>> Btw., congratulations to the merge of the multithreading branch!
>> Regards,
>> Marco
> Hi Marco,
> here ! I think it is essential to allow the user to change the
> choice ? That's where I would go as a user.
> have a +towgs84 defined in their definition, but several towgs84
> have to answer that, and if something else than the default
> coefficients is chosen, the result is incompatible with the proj4
> definition. Should we strip these CRS definitions of the towgs84
> coefficients (which were only meant for a small area initially, so are
> not valid everywhere)?
> Regards,
> Leyan
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
