[Qgis-developer] Some notes of 2.2. OpenSuse 12.3 ""release"
Olivier Dalang olivier.dalang at gmail.com
Tue Feb 25 10:50:19 PST 2014
> 1. Manage and Install Plugins ... -> Upgradeable ; I've two left after I
> upgraded all others.
> mmqgis and Qgis2threejs both tell "There is a new version available"
 I think the problem comes from the plugin's repository XML : for my "layer
combinations" plugins, the metadata file sets version=1.01, but the
plugin's current version is displayed as 1.1 (both in QGIS's plugin manager
and on http://plugins.qgis.org).
So, the plugins stays marked as "upgradable"... I'm not sure on where to
file tickets for that (since it's probably not in QGIS itself)
Thanks !
Olivier
2014-02-25 15:22 GMT+01:00 Kari Salovaara <kari.salovaara at pp1.inet.fi>:
> Replied privately (due files not for public)
> Cheers,
> Kari
> On 02/25/2014 02:50 PM, Angelos Tzotsos wrote:
>> Hi,
>> On 02/25/2014 05:04 AM, Kari Salovaara wrote:
>>> Hi,
>>> thanks for all developers of huge and fantastic work again.
>>> I've OpenSuse 12.3 updated about per midnight (GMT 24.2.2014 23:00). and
>>> qgis2-2.2.0-6.1
>> Can you please provide a full list of repositories that you have enabled
>> in your 12.3 environment?
>>> I'd some notices of small "bugs". I was not able to use other machinery
>>> so I
>>> don't know ......
>>> I've tried both Upgrade all and Upgrade plugin. Restarted QGIS and tried
>>> again.
>>> They just won't want to be upgraded.
>> Please try to erase those plugins completely from your environment and
>> install again from the Plugins Manager.
>> I cannot reproduce this issue.
>>> Then I uninstalled mmqgis and installed again. Now it has been upgraded
>>> but is
>>> again in the list of upgradeable. If You look the numbering where I
>>> expect the
>>> error lie ?
>>> Installed version: 2014.01.06 (in /home/kari/.qgis2/python/
>>> plugins/mmqgis)
>>> Available version: 2014.1.6 (in QGIS Official Plugin Repository)
>>> - and uninstall->install>result was also
>>> Installed version: 0.06 (in /home/kari/.qgis2/python/
>>> plugins/Qgis2threejs)
>>> Available version: 0.6 (in QGIS Official Plugin Repository)
>>> - those leading zeroes ?
>> Please try to wipe out .qgis2 folder and re-install the plugins.
>>> 2. jp2 (Jpeg2000) files don't work/render at all. That was not a
>>> surprise in
>>> OpenSuse. Have to force kill and restart qgis.
>> It is a surprise to me, openSUSE was the first distribution to have
>> OpenJPEG v2 packaged in Factory...
>> Plus, I can work with jp2 files in 13.1
>> Can you please provide a jp2 file that fails for you so I can test?
>>> 3. in About -> License is missing (totally white) ;)
>> Confirmed, I will take a look at this, thanks.
>>> Regards,
>>> Kari
>>> PS. Installation
>>> QGIS version    2.2.0-Valmiera    QGIS code revision    exported
>>> Compiled against Qt    4.8.4    Running against Qt    4.8.4
>>> Compiled against GDAL/OGR    1.10.1    Running against GDAL/OGR 1.10.1
>>> Compiled against GEOS    3.4.2-CAPI-1.8.2    Running against GEOS
>>> 3.4.2-CAPI-1.8.2 r3921
>>> PostgreSQL Client Version    9.2.4    SpatiaLite Version 4.1.1
>>> QWT Version    5.2.3    PROJ.4 Version    480
>>> QScintilla2 Version
>>> Kari Salovaara
>>> Hanko, Finland
>>> "Volunteers do not necessarily have the time; they just have the heart."
>>> ~Elizabeth Andrew
>> Thank you for your feedback.
>> Best,
>> Angelos
> Kari Salovaara
> Hanko, Finland
> ~Elizabeth Andrew
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140225/c2f4acd6/attachment-0001.html>
