[Qgis-developer] Incosistencies in QGIS Mapserver's GetFeatureInfo WMS responses
Marco Hugentobler marco.hugentobler at sourcepole.ch
Thu Feb 27 23:17:34 PST 2014
Hi Marcel
Thanks for spotting this issue, it will be good to have a consistent
behaviour with / without filter and for all output formats.
Adding geometry / bounding box has been done for showing rubberbands and
for handling search results (zoom to features that match the filter).
Therefore, the bounding boxes need to be included even if 'add geometry
to feature response' is not checked. The added bounding box was meant
for cases where the geometry data should be kept private, but searching
should be possible.
I agree with the other points, please prepare a pull request.
Regards,
Marco
On 27.02.2014 14:11, Marcel Dancak wrote:
> Hello,
> I found some inconsistencies in QGIS Mapserver in GetFeatureInfo WMS
> responses in GML format:
> Identification by point coordinates (X/Y or I/J parameters):
>  - returns geometry data of every feature in layer's CRS only if 'Add
> geometry to feature response' in project settings is checked
>  - returns bounding box of every feature in layer's CRS only if 'Add
>  - doesn't returns global bounding box of all matched features collection
> Searching by attributes (FILTER parameter)
>  - always returns geometry data of every feature in layer's CRS
>  - always returns bounding box of every feature in layer's CRS
>  - always returns global bounding box of all matched features
> collection in requested CRS (SRS/CRS parameter), but this value (whole
> XML element) is correct only for text/xml format, because bounding box
> value is computed only for text/xml format, but it's XML element is
> included in server response regardless of concrete XML output format.
> I'm able to fix these issues and prepare pull request(s). This is my
> suggestion:
>  - return geometry data of every feature in requested CRS only if 'Add
> geometry to feature response' is checked
>  - return bounding box of every feature in requested CRS only if 'Add
>  - return global bounding box of all matched features collection in
> requested CRS only if 'Add geometry to feature response' is checked,
> and in proper XML element depending on output format - <BoundingBox
> CRS="EPSG:4326" maxx="1" minx="-1" maxy="1" miny="-1"/> for text/xml
> and <gml:boundedBy><gml:Box srsName="EPSG:4326"><gml:coordinates
> cs="," ts=" ">-1,-1 1,1</gml:coordinates></gml:boundedBy> for GML format.
> Marcel Dancak
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
