[Qgis-developer] Qgis2threejs suggestions...
Geo DrinX
geodrinx at gmail.com
Thu Jan 2 03:24:56 PST 2014
... it seems to be WebKit. Who knows if it loads WebGL on other
platforms, different from Windows ?
2014/1/2 Geo DrinX <geodrinx at gmail.com>
> Minoru,
> this is my ( experimental starting ) test plugin for "webbrowser":
> https://drive.google.com/file/d/0Bwg_m86uaXY1ZWstOWZ3aER2cDQ/edit?usp=sharing
> Simply, drag and drop a url link inside the web view. For example:
> http://opensciencemap.org/map/#scale=12,rot=0,tilt=65,lat=42.3502,lon=13.3988
> and you will have the message:
> "Sorry, your browser doesn't seem to support WebGL"
> How to discover what browser is used by Qt ? I will investigate ...
> Roberto
>> > Then, with the new year, I had an idea: what do you think of a QT
>>> window
>>> > inside QGIS, which displays the 3D html page ?
>>> > Could it be doable ? Do you have just tested ?
>>> Interesting, but I have not tested it yet.
>> I tested now, but I had:
>> But, test it yourself, also. Who knows if you have some "magical"
>> settings on your machine...
>> Roberto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140102/3547f335/attachment.html>
