[Qgis-developer] Qgis2threejs suggestions...
gene
martin.laloux at gmail.com
Fri Jan 3 02:32:48 PST 2014
Hi Minoru,
First of all, many thanks for your plugin.
As I use Mac OS X and the QGIS version of Kyngchaos, the path of gdalwarp is
/Library/Frameworks/GDAL.framework/Versions/1.10/Programs/gdalwarp but this
QGIS version does not recognize the PATHs defined in the UNIX environment
of MAC OS X ie:
export PATH=/Library/Frameworks/GDAL.framework/Programs:$PATH
which gdalwarp
/Library/Frameworks/GDAL.framework/Programs/gdalwarp
So I had to make some changes in your qgis2threejs.py script to run on Mac
OS X with this version of QGIS.
I know that you can not change your script for a specific case but I hope
that this will help Mac users who want to use your plugin.
General:
The os.system() works but it is marked as deprecated in the doc , so I use
the Python module subprocess to make the job (as in Processing or the old
Sextante) and it works:
original line 185
os.system(cmd.encode(fsenc))
my solution:
proc = subprocess.Popen(cmd, shell=True, stdout=subprocess.PIPE,
stdin=subprocess.PIPE,stderr=subprocess.STDOUT)
proc.stdout.read()
(subprocess.check_call(cmd,shell=True) does not work )
Specific to Mac OS X:
- I change the line 182
"cmd = "gdalwarp " + u" ".join(options)"
in
"cmd = "/Library/Frameworks/GDAL.framework/Versions/1.10/Programs/gdalwarp"
- and I have removed the conditional statement
#if not os.path.exists(demfilename):
- the same with line 160 which becomes:
#options.append("--config GDAL_FILENAME_IS_UTF8 NO")
- a final command which works is, for example:
"/Library/Frameworks/GDAL.framework/Versions/1.10/Programs/gdalwarp -r
bilinear -te 201132.706856 87080.384980 206579.284551 91865.013464 -ts 214
188 -t_srs EPSG:31370 "/Users/Shared/Dropbox/my.asc"
"/var/folders/vu/vu099NovH-KZpE5TEa83BU+++TI/-Tmp-/dem20140101164100.tif"
Cosmetic
As I still use Snow Leopard version (witch uses Python 2.6, I know, I know,
it is old, but...), the line 48
locale= localePath = os.path.join(plugin_dir, 'i18n',
'qgis2threejs_{}.qm'
becomes
localePath = os.path.join(self.plugin_dir, 'i18n',
'qgis2threejs_{0}.qm'.format(locale))
(working with Python 2.6.x and 2.7.x versions)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis2threejs-suggestions-tp5095871p5096206.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
