[Qgis-developer] QGIS Server SLD GetStyles method bug?
Alessandro Pasotti apasotti at gmail.com
Fri Jan 3 09:09:04 PST 2014
2014/1/3 rldhont <rldhont at gmail.com>
>  Hi,
> It's just because the STYLE parameter is mandatory in GetMap Request and
> GetStyle is based on it.
> If QGIS-Server will implement multi-styles, STYLE parameter will be
> usefull like in GetMap.
Thanks,
just to be sure: are you saying that GetStyle implementation in QGIS
Mapserver is based on GetMap and hence the parameter is needed (even if
unused) or that the OGC standard says that GetStyle is kind of sub method
of GetMap and it requires all mandatory parameters of GetMap?
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140103/be0c365c/attachment.html>
