[Qgis-developer] problem with forms and python init
Luca Lanteri mescal72 at gmail.com
Tue Jan 7 06:07:13 PST 2014
Hi Enzo,
I return to this old discussion because I noticed that the problem that I
described still remain the same when I use Qgis 2.0. On the contrary when I
use Qgis 2.1 all works fine.
I didn't  full understand this problem previously  because I use qgis 2.0
on my works PC and and 2.1 with linux on my laptop.
Anyway I resolve the problem whit Qgis 2.0 using your tip of QgsFeatureRequest
with NoGeometry flag, so the mail is just to keep track of the problem.
thanks again.
Luca
2013/12/21 Luca Lanteri <mescal72 at gmail.com>
> you are right, the code now works fine.
> It was just my fault due to to the fact that I'm trying to take ones
> first steps with pygis !
> thanks for the support and sorry for the noise.
> Btw I also resolve my second problem described in the first mail.
> thanks
> Luca
> 2013/12/21 Enzo Ciarmoli <enzo.ciarmoli at csi.it>:
> >> > nevertheless the problem remain the same: if i try to load the data
> >> > from a table without geometry, values for i.attributes()[1] remain
> >> > empty.
> > Hi Luca,
> > I tried your sample code and it works... I don't know what's wrong in
> your
> > situation...
> > If your problem remain the same,
> > I could suggest you to use QgsFeatureRequest with NoGeometry flag
> > (see Detailed Description in:
> > http://www.qgis.org/api/classQgsFeatureRequest.html )
> > Example:
> > layer = QgsMapLayerRegistry.instance().mapLayersByName('your_table')[0]
> > iter =
> layer.getFeatures(QgsFeatureRequest().setFlags(QgsFeatureRequest.NoGeometry))
> > for feat in iter:
> >     print feat.attributes()
> >     print feat.attributes()[0]
> >     print feat.attributes()[1]
> > Ciao!
> > Enzo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140107/61b4c458/attachment.html>
