[Qgis-developer] forced update on the repo?
Radim Blazek radim.blazek at gmail.com
Mon Jan 13 06:10:40 PST 2014
On Mon, Jan 13, 2014 at 12:59 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 13 January 2014 22:26, Radim Blazek <radim.blazek at gmail.com> wrote:
>> Could it be that b4d082f9 and 860e23afc7 have wrong date Jan 12 2013?
>> The 860e23afc7 has parent 0c6d9ef90 with Jan 12 2014.
> Arghh... you're right. <hangs head in shame> Is there anyway this can
> be fixed now? My apologies for the inconvenience this has caused...
No problem.
It seems to be fixed by:
git filter-branch --env-filter 'if [ $GIT_COMMIT =
"b4d082f97d82140c55a9b0afee5db06227b9c6b3" ]; then export
GIT_AUTHOR_DATE="1417450920+1100"; export
GIT_COMMITTER_DATE="1417450920+1100"; fi; if [ $GIT_COMMIT =
"860e23afc70b804b7ddc3f2e98f88e7ee5ac995b" ]; then export
GIT_AUTHOR_DATE="1417450860+1100"; export
GIT_COMMITTER_DATE="1417450860+1100"; fi' 224e34010aa..HEAD
Note that checksums of those two commits and all following commits will change.
Then you need to be courageous enough to run the very dangerous git
push -f. I am not. Please verify everything 10 times before push.
Could please someone third try to run the command above and confirm
that it corrects the dates and does not do any damage and can be
followed by git push --force?
I am not git expert.
Until we fix that, please do not commit to GitHub and preferably do
not comment commits after the problematic commits because checksums
will change.
Radim
