[Qgis-developer] Open custom form from another form
Luca Lanteri mescal72 at gmail.com
Tue Jan 14 08:52:51 PST 2014
yeah !
IMHO the 1 to many feature is one of the best improvement of the 2.1 qgis
version. It solve to me a lot of work's problem.
Qgis Rulez!
I tried your tips and now all works fine.
Usually the problem for me is moving into API class reference. I need to
study it deeply.
Thanks a lot
Luca
2014/1/14 Denis Rouzaud <denis.rouzaud at gmail.com>
>  Hi Luca,
> Since two months, it does support custom ui form [0]
> You have to place a widget in your form and a dynamic property to the
> widget.
> You call it qgisRelation and set it to the id of the relation.
> Cheers,
> Denis
> [0]
> https://github.com/qgis/QGIS/commit/08b43aadd19414d267f86082f7d865f3abc179d1
> On 14. 01. 14 17:09, Luca Lanteri wrote:
> Hi denis,
> thanks a lot for the tip,I'll try it immediately.
>  I know the brand new "1 to many" feature present in qgis 2.1 and it's
> gorgeous, but as I know it works only with autogenerate forms, but I need
> to use a custom forn because I have some code into it.
>   many thanks
> Luca
>>  Hi Luca,
>> The best way to do this, is to set your personnally designed UI file in
>> the layer properties->field properties->attribute editor layout->provide ui
>> file
>> Then, you want to call qgis method to show a feature form:
>> http://qgis.org/api/classQgisInterface.html#aff2467aa3cefd8fc5b59213f385b7180
>> And you would need some processing to show it:
>> 1. get feature id from the selected line
>> 2. fetch the feature of the main layer
>> 3. get the foreign key from one of its fields
>> 4. fetch the corresponding feature
>> 4. show the feature form with it
>> Anyway, if I understand properly, you're trying to do something which has
>> been recently added to QGIS (it's in the master version), it's 1:n
>> relations.
>> See here for more info:
>> http://blog.vitu.ch/10112013-1201/qgis-relations
>> Cheers,
>> Denis
>> On 14. 01. 14 16:50, Luca Lanteri wrote:
>>  Hi to all,
>>  I need a help from a python guru. I'm trying to move my first steps
>> with pyqgis.
>>  I've got two qgis layer with a 1 to many relation. I create a custom
>> form for the parent layer with a QTableWidget that contain the primary key
>> of the child layer. Now I want to open another custom form with the data of
>> the child record selected into the QTableWidget. I try to look up into the
>> QGIS API Documentation but I'didn't find the solution to my problem.
>>  Now I just can open form with this code, connected with a button:
>>      path = os.path.dirname( os.path.abspath( __file__ ) )
>>     uifile = os.path.join(path , my_form.ui')
>>      window = uic.loadUi(uifile)
>>     window.exec_()
>>  how can I connect my form with the right data ?
>> Can I use some method to select the right layer/record and open it in the
>> form ?
>>  Thanks in advance for any tips
>>  Luca
>>  _______________________________________________
>> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140114/006068fb/attachment-0001.html>
