[Qgis-developer] Qgis web client search
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Jan 16 03:14:21 PST 2014
try to enter the url of the wsgi-script directly in your browser and see
what it returns, check QWC's log file for any errors of the wsgi script.
Bernhard
Am 16.01.2014 12:09, schrieb Mira Maric:
> I set up Apache config file:
> insert following lines:
> - LoadModule wsgi_module modules/mod_wsgi.so
> and
>   WSGIScriptAlias /wsgi C:\OSGeo4W\apache\htdocs\qgis-web-client-master\wsgi
>   WSGIScriptAliasMatch ^/wsgi/([^/]+)
> "C:\OSGeo4W\apache\htdocs\qgis-web-client-master\$1.wsgi"
> , after this I create tables in Posgis and modify connection string in
> search.wsgi and getSearchGeom.wsgi.
> Now when I run web page and try to search in search box I get this error:
> Resource interpreted as Script but transferred with MIME type text/plain:
>   "http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=89&cb=stcCallback1001".
> ext-all.js:7
> Uncaught SyntaxError: Unexpected token ILLEGAL search.wsgi:1
> 2014/1/16 Bernhard Ströbl<bernhard.stroebl at jena.de>:
>> Hi,
>> I have no idea, where this is located on Windows...
>> but you need to adapt the wsgi files you downloaded from github with QWC to
>> your db settings (see section 6.2)!
>> Bernhard
>> P.S. please try to reply to the list
>> Am 16.01.2014 10:17, schrieb Mira Maric:
>>> Hi!
>>> I do the following:
>>> I download mod_wsgi.so from
>>> http://www.lfd.uci.edu/~gohlke/pythonlibs/#mod_wsgi an put it in:
>>> C:\OSGeo4W\apache\modules
>>>    In Apache config file I added line:
>>>       -LoadModule wsgi_module modules/mod_wsgi.so
>>> I restart apache and turn it on, it's work OK. Now I don't know  where
>>> to do this, where is file for this settings?
>>> I am using Windows!
>>>     6.1. Configuration of mod_wsgi
>>> You need to enable mod_wsgi as root. (Ubuntu: a2enmod mod_wsgi).
>>> You need to configure apache with the following lines (e.g. in file
>>> /etc/apache2/sites-available/default):
>>>     #mod_wsgi
>>>     WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
>>>     WSGIScriptAlias /wsgi/ /home/www/wsgi/
>>>     WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
>>> Thanks!
>>> 2014/1/16 Mira Maric<mmmxxxm at gmail.com>:
>>>> Hi!
>>>> I do the following:
>>>> to do this
>>>> Uncaught SyntaxError: Unexpected token ILLEGAL in search.wsgi:1
>>>>> Hi,
>>>>> did you configure the wsgi scripts to match your database and did you
>>>>> provide the search tables in the database?
>>>>> Both is described in the README (section 6) [1]
>>>>> Bernhard
>>>>> [1] https://github.com/qgis/QGIS-Web-Client
>>>>> Am 16.01.2014 07:33, schrieb Mira Maric:
>>>>>>    1.
>>>>>>       First I added line in Apache config file:
>>>>>>    2.
>>>>>>       In GlobalOption.js I set var useGeoNamesSearchBox = false; var
>>>>>>       searchBoxQueryURL
>>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=";
>>>>>>       var searchBoxGetGeomURL
>>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/getSearchGeom.wsgi";
>>>>>> When i try to search, i do not get anything! Is there any example for
>>>>>> searching setup?
__________ Information from ESET Mail Security, version of virus signature database 9297 (20140116) __________
The message was checked by ESET Mail Security.
http://www.eset.com
