[Qgis-developer] Mmqgis error making a buffer
Andre Joost andre+joost at nurfuerspam.de
Fri Jan 17 11:44:55 PST 2014
Am 17.01.2014 16:56, schrieb Geodrinx:
>> What did you input as radius?
> I tested with 1000 and with 1000.00 (but any other value has the same effect )
> I tested with points and with a line.
> The srs was epsg:32632.
> But also other srs has the same effect. :(
> Is it working to you ?
Yes, but I don't use an Apple ;-)
What about Vector -> Geoprocessing -> Buffer?
Greetings,
André Joost
