[Qgis-developer] Troubles with QgsAttributeTableView in a plugin
Matthias Kuhn matthias.kuhn at gmx.ch
Mon Jan 20 00:37:09 PST 2014
Hi Radosław,
Things like this are most likely introduced by loosing the reference to
objects which then get garbage collected.
Try assigning the objects to local variables. I.e. change "model" to
"self.model", "filterModel" to "self.filterModel" etc.
Hope this helps
Matthias
On Sun 19 Jan 2014 04:18:09 PM CET, Radosław Pasiok wrote:
> Hello Devs!
> I would like to ask you for help with using a QgsAttributeTableView in
> a plugin. I am using QGIS-master on Ubuntu 12.04 but the same applies
> to QGIS-dev from OSGeo4W.
> There is no problem when I use QGIS python console:
> from PyQt4.QtCore import *
> from PyQt4.QtGui import *
> from qgis.core import *
> from qgis.gui import *
> w = QMainWindow()
> cw = QWidget(w)
> gridLayout = QGridLayout(cw)
> w.setCentralWidget(cw)
> tv = QgsAttributeTableView(cw)
> gridLayout.addWidget(tv, 0, 0, 1, 1)
> xs = iface.mapCanvas().currentLayer()
> xsCache = QgsVectorLayerCache(xs, 10)
> model = QgsAttributeTableModel(xsCache)
> model.loadLayer()
> filterModel = QgsAttributeTableFilterModel(iface.mapCanvas(), model)
> tv.setModel(filterModel)
> w.show()
> When using the some code in a plugin :
> class TableViewDialog(QMainWindow):
>     def __init__(self, parent, iface):
>         QMainWindow.__init__(self)
>         self.ui = Ui_TableView()
>         self.ui.setupUi(self)
>         self.iface = iface
>         self.ui.refreshButton.clicked.connect(self.refresh)
>     def refresh(self):
>         tv = self.ui.tableView
>         xs = self.iface.mapCanvas().currentLayer()
>         model.loadLayer()
>         filterModel =
> QgsAttributeTableFilterModel(self.iface.mapCanvas(), model)
> I cannot get the table populated with features and QGIS crashes
> occasionally when refresh() is called. The tableView object is
> promoted to QgsAttributeTableView with header 'qgis.gui'.
> What could make the difference between those two cases. Am I missing
> something in the plugin code?
> Thank you for any hint!
> Radek
> Używam wolnego oprogramowania:
> http://www.gnu.org/philosophy/philosophy.pl.html
> Qgis-developer mailing list
