[Qgis-developer] Qgis2threejs suggestions...
Geo DrinX geodrinx at gmail.com
Mon Jan 20 00:43:38 PST 2014
Hi Minoru,
All is OK, now.    It was my local "webbrowser"  test plugin, that
conflicted with your.
Now, QGis2threejs  works perfettly
Thank you
Roberto
2014/1/19 Geodrinx <geodrinx at gmail.com>
> Inviato da iPhone
> Il giorno 19/gen/2014, alle ore 10:06, Minoru Akagi <akaginch at gmail.com>
> ha scritto:
> > Hi Roberto,
> > Is your python webbrowser module overlapped by something? For example,
> > you have a plugin named "webbrowser" ? : )
> Yes, I created a plugin named "webbrowser" ... :(
> So, this is the problem !
> > Otherwise, please try to
> > set browser path in the setting dialog.
> Ok, thank you.  I will inform you.
> Regards
> Roberto
> > Regards,
> > Minoru
> > 2014/1/18 Geo DrinX <geodrinx at gmail.com>:
> >> Hi Minoru ,
> >> I taken QGis2threejs now from  repository and I am testing on  MacOSX.
> >> I had this:
> >> Traceback (most recent call last):
> >>  File
> >> "/Users/rrr/.qgis2/python/plugins/Qgis2threejs/qgis2threejsdialog.py",
> line
> >> 334, in run
> >>    if not tools.openHTMLFile(htmlfilename):
> >>  File
> "/Users/rrr/.qgis2/python/plugins/Qgis2threejs/qgis2threejstools.py",
> >> line 128, in openHTMLFile
> >>    webbrowser.open(htmlfilename, new=2)    # new=2: new tab if possible
> >> AttributeError: 'module' object has no attribute 'open'
> >> Versione Python:
> >> 2.7.1 (r271:86832, Jun 16 2011, 16:59:05)
> >> [GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)]
> >> Also on Windows 7  I have the same…
> >> Tell me if you need more info to debug.
> >> Roberto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140120/ad62c8c2/attachment-0001.html>
