[Qgis-developer] Qgis2threejs suggestions...
Geodrinx geodrinx at gmail.com
Mon Jan 20 21:54:52 PST 2014
>>  if there are more than one  DTM_  layers, it could be
>> possible to have together clipped in the output ?   Or, only one is possible
>> to have ?
> Only one. You should merge DTM files into one in advance or make use
> of vrt file.
If I well understand from documentation, a .vrt file is an xml index of many raster files.
It is correct ?
And QGis supports it, true ?
I will try it as soon as possible :)
Thank you for the great suggestion
Roberto
