[Qgis-developer] option to disable font vectorization in labels
Anita Graser anitagraser at gmx.at
Tue Jan 21 09:56:41 PST 2014
Am 21.01.2014, 10:24 Uhr, schrieb Vincent Mora <vincent.mora at oslandia.com>:
> The question is where to put this option ?
> So far I think of 3 places:
> - a global project option: you will see the result in the canvas as you
> work
> - a layer label option: in this case you have to change the behavior for
> each layer
> - a composer option: you make the choice when you export to svg, in this
> case you don't see the result until you open the svg
Thanks for addressing this issue!
For me, the most obvious place to put this option would be in the print
composer. Maybe close to the "print as raster" option?
Best wishes,
Anita
anitagraser.com
