[Qgis-developer] Viewing SpatiaLite views in QGis
Vincent Mora vincent.mora at oslandia.com
Thu Jan 23 04:36:24 PST 2014
http://www.gaia-gis.it/gaia-sins/spatialite-cookbook/html/sp-view.html
recommend to insert spatial view in *views_geometry_columns.*
Note: I had problems trying to use OGC_FID instead of ROWID as the PK
for the view.
On 23/01/2014 09:26, Geo DrinX wrote:
> Hello all,
> I noticed a strange behavior in QGis when I am viewing SpatiaLite views.
> These are my steps:
> 1)  I have some SpatiaLite tables, that have  "Geometry" field.  For
> example:
> CREATE TABLE "Poligoni" (
> "PK_UID" INTEGER PRIMARY KEY AUTOINCREMENT,
> "field1" TEXT,
> "Note" TEXT, "geometry" POLYGON)
> 2) I create a SpatiaLite view, that performs some spatial opetation,
> i.e.  an intersection
> CREATE VIEW intersecato as
> SELECT  b.field1as "field1", b."field2" AS "field2", a."field3" AS
> "field3",
>     ST_area (a.Geometry) AS "area", b.arec as "arec",
>  intersection (a.Geometry, b.Geometry) as Geometry
> FROM "Poligoni" a, "otherTable" b
> where
> ST_intersects (a.Geometry, b.Geometry)  = 1
> order by field1
> 3)  I insert into "geometry_columns" a record for the view:
> insert into geometry_columns values
> ('intersecato','geometry',3,2,3003,0)
> 4)  I execute a query into SpatiaLite_gui to control that some record
> exists.
>      And...  they exist.   :)
> 5) I go to QGis (2.0.1 Dufour,  Windows, Linux or MacOSX :)   and
> connect to SpatiaLite DB.
> 6) I insert my tables and view in Layer list.
> We, now I see all the layers, as those corresponding to the tables, as
> that correspond to my SpatiaLite view.  But, this one do not display
> the correct records in the attribute panel: in this case, I only have
> a list of many "NULL", and selecting a record, all records are
> selected  :(
> Do you have any explanation for this?
> Also I tried to add a PK_UID  in the view definition, but the result
> remains the same.
> Thank you for any help
> Regards
> Roberto
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140123/09c8bf6b/attachment.html>
