[Qgis-developer] Multigeom postgis tables display
Paolo Cavallini cavallini at faunalia.it
Thu Jan 23 22:56:45 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 24/01/2014 07:39, Sandro Santilli ha scritto:
> I haven't had an use either (while I'm full of those tables).
> Geometries are usually not something that you want to edit "manually",
> especially using a desktop GIS...
> But it could be interesting to see if simply displaying less of it
> (limit on size, click to expand?) would get the speed back. There would
> be the same problem with big values of other data types (think text).
Hi all.
The speed issue could be solved by using the same approach of DB Manager (reading and
displaying only the geometry type). This could also avoid the problem with editing.
However, I do not see any reason to show an user geometry columns, and in case there
is a reason, why showing only non-loaded geometries?
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlLiDqUACgkQ/NedwLUzIr791gCeLaDWMcGgbMgtDTCrTAvYcAeS
MlYAn29LKoa9/3bOMicIigvfyI/iv1qY
=eymt
-----END PGP SIGNATURE-----
