[Qgis-developer] Can we deactivate the Select datum transformations dialog by default?
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Jan 24 04:42:33 PST 2014
>now I think I understand what do you mean. I just noticed that in QGIS
>master the towgs parameters of CRSs in use for Portugal have vanished.
>Is on purpose or should I consider it a bug?
Looks like a bug. When did it appear? I did not do any changes to the
datum transform code in the last month.
Regards,
Marco
On 24.01.2014 12:20, Giovanni Manghi wrote:
> Hi Marco
>> I can live with either showing / not showing by default.
>> Just note that without showing, many people are receiving wrong
>> transformation results without any hint.
> for example in QGIS there are both the epsg 20790 that had the
> parameters and its counter part without (102164) and the user was able
> to choose between the two, choosing if he wanted the shift of not.
> If the parameters removal was on purpose (also for other CRSs for
> other countries) then we can have a serious issue.
> Also I have personally a lot of difficulties understand how the datum
> shift dialog works, then I guess that most of the people will have the
> same problem :)
> ntv2 grids were also added to the datum shift database, but never
> managed to have them show in the dialog. What I'm doing wrong?
> cheers!
> -- Giovanni --
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
