[Qgis-developer] Issue with standalone python script and PostGIS Layers
Stott James fmrojst at fylkesmannen.no
Fri Jan 24 06:23:55 PST 2014
Following on from reporting the bug, I have done more digging into the problem.
It seems to be related to styleQML lines when I check what connections are being sent to PostGIS. These don't disappear with each loop iteration in Master, but they do in version 2.0. Eventually when my script gets to 100 connections, it hangs.
What can I do to make this work?
I have updated the bug report with more details, which can be found here https://hub.qgis.org/issues/9357.
James
Fra: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] På vegne av Stott James
Sendt: 16. januar 2014 14:23
Til: Tim Sutton
Kopi: qgis-developer at lists.osgeo.org
Emne: Re: [Qgis-developer] Issue with standalone python script and PostGIS Layers
Thanks for the response Tim.
I have not been destroying my layers. This has not been an issue when running the plugin with 2.0.
This was the first thing I thought about in the version running against master so I added the following code to close the postgis layers as it once I am finished with them:
QgsMapLayerRegistry.instance().removeMapLayer(layer_id)
This has not made it difference. It still hangs at the same place and I still get the warning that there is already too many clients when trying to connect to PostGIS with DB Manager or pgAdmin.
Shall I open a bug?
Fra: Tim Sutton [mailto:lists at linfiniti.com]
Sendt: 16. januar 2014 13:30
Til: Stott James
Kopi: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Hi
On Thu, Jan 16, 2014 at 11:06 AM, Stott James <fmrojst at fylkesmannen.no<mailto:fmrojst at fylkesmannen.no>> wrote:
Hello all,
I have a standalone python script that creates a bunch of PDFs for me.
Recently this script has developed an issue. It uses QGIS-dev so it could be related to some of the changes in master recently as it works fine with QGIS 2.0.
It makes about 42 PDFs then it stops.
It is not actually crashing as such, as you can see it running in task manager. It stays running using between 0 and 2% processor, and fluctuates a little with memory use (around 108840kB). But it does not produce any more PDFs. It is like it is stuck.
>From the log file that my script creates, I know that it is hanging with this line of code:
vlayer = QgsVectorLayer(uri.uri(), layerName, "postgres")
If I try and connect to the database using DB Manager in QGIS or pgAdmin III while the script is still running, I get an error saying there is already too many clients already. If I kill the process in windows task manager, I am then able to connect to the database using DB manager.
Has anyone any suggestions as to what is wrong here? Is this a bug?
I updated QGIS dev this morning using the OSGeo4W installer (its revision is eb9ce3a).
If you are creating postgis layers in a loop, are you making sure to destroy them again nicely in your loop? Anyway if it used to work before maybe there was a regression somewhere....
Regards
Tim
James Stott
GIS-koordinator
Administrasjonsavdelinga
Fylkesmannen i Rogaland
Telefon: 51568793
james.stott at fylkesmannen.no<mailto:james.stott at fylkesmannen.no>
http://www.temakart-rogaland.no
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net<http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140124/beda7015/attachment-0001.html>
