[Qgis-developer] QGIS and 3D
G. Allegri giohappy at gmail.com
Mon Jan 27 09:23:01 PST 2014
Shouldn't we create e wiki page about QGIS and 3D? We could gather these
links there.
giovann
2014-01-27 gene <martin.laloux at gmail.com>
> Among others:
>  In French:
> -  PyQGIS (QGIS 2): les coupes géologiques (colorisation d'un profil
> topographique élaboré à partir d'un MNT en fonction des couleurs d'un
> raster
> et placement des points d'intersection avec les limites des couches
> géologiques)
> http://www.portailsig.org/content/pyqgis-qgis-2-les-coupes-geologiques-colorisation-d-un-profil-topographique-elabore-partir-d
> (PyQGIS (QGIS 2) geological cross-sections ("colorization" of a topographic
> profile with the colors of a geological map and placement of the points of
> intersection with the boundaries of geological layers)).
> In Spanish:
> -  QGIS, visualización 3D de capas vectoriales con Python
> http://geotux.tuxfamily.org/index.php/en/geo-blogs/item/315-qgis-visualizacion-3d-de-capas-vectoriales-con-python
> but also in this list, for example:
> -  visualizing 3D data (Z values) or data with z attribute: a solution
> http://osgeo-org.1560.x6.nabble.com/visualizing-3D-data-Z-values-or-data-with-z-attribute-a-solution-td5005360.html
> -  For geologists: 3D geological boreholes
> http://osgeo-org.1560.x6.nabble.com/For-geologists-3D-geological-boreholes-td5007085.html
> and in GIS Stack Exchange, for example:
> -  TIN Interpolation using a vector layer
> http://gis.stackexchange.com/questions/41891/tin-interpolation-using-a-vector-layer/41922#41922
> -  Create cross section with polygon intersects in QGIS
> http://gis.stackexchange.com/questions/83605/create-cross-section-with-polygon-intersects-in-qgis/83619#83619
> - with only Python:
> -  Display a georeferenced DEM surface in 3D matplotlib
> http://gis.stackexchange.com/questions/66367/display-a-georeferenced-dem-surface-in-3d-matplotlib/66440#66440
> http://osgeo-org.1560.x6.nabble.com/QGIS-and-3D-tp5099845p5100283.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140127/cbafc982/attachment-0001.html>
