[Qgis-developer] [postgis-users] QGis 2.0 Copy/Paste from shapefile to Postgis issue if the primary key is a string
Denis Rouzaud denis.rouzaud at gmail.com
Fri Jan 31 06:12:26 PST 2014
QGIS prevent to overwrite the primary key field when it copies/pastes,
this is why it leaves the field empty.
One way would be to add the constraint after the copy/paste if it's for
a single shot.
Otherwise, just add a unique constraint on f1 and add a serial as
primary key.
Cheers,
Denis
On 31. 01. 14 15:02, F T wrote:
> Hello
> We have a pb with copy/paste from a shapefile to postgis if the
> primary key is a string.
> The primary key is left NULL and no commit is possible.
> To reproduce the pb :
> Create *table1 *with a string primary key
>     CREATE TABLE table1
>       f1 character varying(10) NOT NULL,
>       f2 character varying(10),
>       geom geometry,
>     *CONSTRAINT t1_pkey PRIMARY KEY (f1),*
>     CONSTRAINT enforce_dims_geom CHECK (st_ndims(geom) = 2),
>     CONSTRAINT enforce_geotype_geom CHECK (geometrytype(geom) =
>     'POINT'::text),
>     CONSTRAINT enforce_srid_geom CHECK (st_srid(geom) = 2154)
> *table2* is the same as table 1 but it has no primary key
>     CREATE TABLE table2
>       geom geometry,
>     'POINT'::text),
> *shapes.shp* is a shapefile that contains the points I would like to
> copy/paste in the Postgis tables
> (see attached zip file)
> 1) if I copy/paste the points from shapes.shp to table1, the key field
> stays NULL and the commit is impossible.
> 2) if I copy/paste the points from shapes.shp to table2, everything is ok.
> Have you ever seen this bug?
> Thanks
> Fabrice
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140131/49857739/attachment.html>
