[Qgis-developer] Enable snapping on intersections
Jakob Lanstorp jlanstorp at gmail.com
Fri Jan 31 06:46:46 PST 2014
Snap to intersection makes you snap to just that intersection point. Did a
test with two polygon layers and a point layer. Adding a point to the point
layer, while within the snap tolerance, made the point appear right on the
intersection between the two polygon layers. Removing the 'Enable snapping
on intersection' made the point not snap to the intersection.
I have set snapping settings to both polygon layers, prehaps you missed that
in the snap options.
Jakob Lanstorp
View this message in context: http://osgeo-org.1560.x6.nabble.com/Enable-snapping-on-intersections-tp5101200p5101219.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
