[Qgis-developer] why Difference takes much more time then Clip?
G. Allegri giohappy at gmail.com
Tue Jul 1 13:57:15 PDT 2014
Just two graphics two show a brutal benchmark (measuring time in every
cycle step).
Clip: http://cdn.img42.com/31e0205c1273a1d1c705e5109da48db1.png
Difference: http://cdn.img42.com/eeba68e62ea7d4db50662c2745a6d912.png
2014-07-01 20:05 GMT+02:00 G. Allegri <giohappy at gmail.com>:
> To be correct, the two postgis queries are:
> select min(l.osm_id),st_difference(l.geom,st_union(e.geom)) as geom from
> linee_selezione_s l join edifici_buffer_s e
> on ST_Intersects(l.geom, e.geom) group by l.geom
> select min(l.osm_id),st_intersection(l.geom,st_union(e.geom)) as geom from
> 2014-07-01 19:37 GMT+02:00 G. Allegri <giohappy at gmail.com>:
> I'm doing some tests on fTools/Processing spatial operators, with a cover
>> multilinestring layer and a base polygon layer.
>> Running the following query on PostGIS I get similar timings with
>> st_intersection and st_difference:
>> select l.osm_id,ST_intersection(l.geom,e.geom) as geom from
>> linee_selezione as l,edifici_buffer as e where ST_Intersects(l.geom, e.geom)
>> while if I run the Difference tool QGIS chokes and it takes magnitudes of
>> more time then Clip.
>> If made both tools as similar as possible, just changing this [1] line of
>> code, but the difference in execution time remains big.
>> I can't find out where is the difference, because both PostGIS and QGIS
>> base the operations on GEOS.
>> Any hints?
>> giovanni
>> [1]
>> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/qgis/ftools/Clip.py#L107
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> Twitter: https://twitter.com/_giohappy_
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Giovanni Allegri
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140701/0ff0d740/attachment.html>
