[Qgis-developer] Openlayers plugin support in QGIS 2.4
René-Luc Dhont rldhont at gmail.com
Mon Jul 7 00:54:12 PDT 2014
Hi Ali,
You'll find examples here :
http://www.gdal.org/frmt_wms.html
Remember that using Google Maps needs to accept the Google licence.
Regards
René-Luc
Le 07/07/2014 09:42, Aamir Ali a écrit :
> Thanks for your prompt response
> I need to call google maps, how can I use TMS service to call the
> tiles from Google Map.
> Regards
> Ali
> On Mon, Jul 7, 2014 at 11:53 AM, René-Luc Dhont <rldhont at gmail.com> wrote:
>> Hi Ali,
>> You can use this method instead of OpenLayers Plugin :
>> Using Map Tile Servers in QGIS 2.4
>> http://www.konstantingreger.net/using-map-tile-servers-in-qgis-2-4/
>> Based on :
>> How to display OpenStreetMap data tiles with no plugin inside Qgis
>> http://www.3liz.com/blog/rldhont/index.php?post/2012/07/17/OpenStreetMap-Tiles-in-QGIS
>> Regards,
>> René-Luc D'Hont
>> Le 07/07/2014 07:38, Aamir Ali a écrit :
>>> Dear All
>>> I am using QGIS 2.4 built using qgis source code and qt creator in
>>> ubuntu. I am unable to find openlayers plugin in the list of plugin
>>> repository. I have a two questions
>>> 1. Whether it is not compatible with this version or my build has some
>>> problems?
>>> 2. If its not compatible then how long it will take the community to
>>> release the compatible version?
>>> Aamir Ali
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
