[Qgis-developer] SOSI support in QGIS
Stott, James fmrojst at fylkesmannen.no
Mon Jul 7 05:16:52 PDT 2014
Hi Jürgen,
So with further testing it appears we have found some problems with other SOSI files.
It seems things work quite well with simple files (like the naturvernområde data for Rogaland I and others have tested with), but we get problems when opening bigger files.
One thing we have noticed is that a lot of the problems seem to happen when you try and load more than one type of geometry types from a sosi file at once. If I select all 3 geometry types in one go (or load 2 or more individually) QGIS crashes. If we just load one geometry type, and then close it and load another geometry type, it works fine.
We are also getting problems with files that contain a lot of data, in this situation QGIS will crash with just one layer loaded.
And when QGIS starts to error, I get the noise problem mentioned here too http://hub.qgis.org/issues/10746 .
So a few issues, but it's a great start that it works with some data :)
If people would like copies of these datasets for testing, I can provide them.
James
-----Opprinnelig melding-----
Fra: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] På vegne av Stott, James
Sendt: 6. juli 2014 16:42
Til: Jürgen E. Fischer; qgis-developer at lists.osgeo.org
Emne: Re: [Qgis-developer] SOSI support in QGIS
Hi Jürgen,
1.11.0-4 fixes this problem.
Thanks for the help.
James
________________________________________
From: qgis-developer-bounces at lists.osgeo.org [qgis-developer-bounces at lists.osgeo.org] on behalf of Jürgen E. Fischer [jef at norbit.de]
Sent: 06 July 2014 16:17
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] SOSI support in QGIS
Hi James,
On Sun, 06. Jul 2014 at 13:53:57 +0000, Stott, James wrote:
> One other thing I have noticed on 64 bit is that gdal-python package
> has a different version number (1.11.0-3) than in 32 bit (1.11.0-2).
> This version number is different to all the other packages which are 1.11.0-2.
Try 1.11.0-4 please
Jürgen:
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
