[Qgis-developer] Attribute Form Editor
Matthias Kuhn matthias.kuhn at gmx.ch
Thu Jul 10 14:27:53 PDT 2014
Hi Boesiii,
Please file a bug. Before 2.2 it worked only for certain edit types and
was quite a hack to have it working for these.
With the new widget system it should be easy to implement the same
behavior for (almost?) all widget types.
Best,
Matthias
On 07/10/2014 09:20 PM, boesiii wrote:
> In Qgis 2.2 I had a form with tabs.  In each tab I repeated the same
> attribute at the top along with other attributes that did not repeat.  When
> I updated the attribute which repeated on each tab the same attribute would
> update on each tab.  In 2.4, when I update the repeating attribute on one
> tab it does not repeat the update on other tabs and will not save the change
> unless all repeating attributes have the same value.
> Shall I file a bug report?
> <http://osgeo-org.1560.x6.nabble.com/file/n5150550/form.png>
> <http://osgeo-org.1560.x6.nabble.com/file/n5150550/form2.png>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Attribute-Form-Editor-tp5150550.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
