[Qgis-developer] Compiling QGIS and C++ Application with QGIS Headers on Windows 8.1
Jürgen E. Fischer jef at norbit.de
Fri Jul 11 06:52:09 PDT 2014
Hi Joshua,
On Fri, 11. Jul 2014 at 09:29:11 -0400, Joshua Quesenberry wrote:
> I'm trying to follow the instructions on the INSTALL page
> (http://htmlpreview.github.io/?http://github.com/qgis/QGIS/blob/master/doc/I
> NSTALL.html )
> My current setup is this:
> Windows 8.1
> Visual Studio Express 2013
> QGIS was standalone installed a month or so ago and is version 2.2.0
> QT 5.3
QGIS doesn't support Qt 5.x yet.
If you want to use the dependencies from OSGeo4W, you'll have to use
the tools they were build with (especially the C++ dependencies like Qt; ie.
VC2008 on 32bit and VC2010 on 64bit).
If you build your own Qt using VC 2013 might also be an option.  But I'd
recommend to stick to INSTALL and use the dependencies from OSGeo4W.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
