[Qgis-developer] slow loading projects (with layouts) and crashes when "renders layers in parallel using many CPS cores" is ON
Martin Dobias wonder.sk at gmail.com
Wed Jul 16 15:19:53 PDT 2014
Hi
On Wed, Jul 9, 2014 at 6:13 PM, Giovanni Manghi
<giovanni.manghi at faunalia.pt> wrote:
> Hi all,
> there are reports in the bug tracker about two situations in qgis 2.4.
> I would like to know if anyone else confirms:
> * it seems that adding print layouts make loading of projects more and
> more slow, this was not the case in 2.2
> http://hub.qgis.org/issues/10828#note-17
This should be fixed now in master.
> * qgis 2.4 seems that can become unstable if "renders layers in
> parallel using many CPS cores" is ON and/or the number of cores used
> is high
> http://hub.qgis.org/issues/10778#note-13
> http://hub.qgis.org/issues/10744#note-6
Problems with CSV files should be fixed too, but there are likely some
problems also in projects without CSV files. Any hints helping to
replicate the problems would be appreciated...
Regards
Martin
