[Qgis-developer] compile error
Nathan Woodrow madmanwoo at gmail.com
Tue Jul 22 02:28:08 PDT 2014
Are you on the latest code? This build error was fixed last night.
On Jul 22, 2014 7:27 PM, "Jorge Tornero - Listas" <jtorlistas at gmail.com>
wrote:
> Hello all,
> Same happened to me some minutes ago. A second run of make just make it
> compile (I dindn't do nothing, don't ask :) ). I'm on Kubuntu 14.04.
> Anyway, I get an error (posted yesterday) when running the compiled source:
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
>   File "/home/antares/dev/QGIS/build/output/python/qgis/gui/__init__.py",
> line 1, in
>     from qgis._gui import *
> ImportError: dynamic module does not define init function (init_gui)
> Python version:
> 2.7.6 (default, Mar 22 2014, 23:03:41)
> [GCC 4.8.2]
> QGIS version:
> 2.5.0-Master 'Master', 8f0b898
> Don't have any clue about that. I've found and issue in the hub:
> https://hub.qgis.org/issues/10218
> But it doesn't say much about how to solve (just fixed problem)
> Maybe it is matter of a ticket?
> Best regards
> El 22/07/14 11:02, Ziegler Stefan escribió:
>> Hi
>> I get an compile error on master:
>> [ 98%] Building CXX object python/CMakeFiles/python_
>> module_qgis__analysis.dir/analysis/sip_analysispart3.cpp.o
>> Linking CXX shared library ../output/python/qgis/_analysis.so
>> [ 98%] Built target python_module_qgis__analysis
>> [ 98%] Built target pyanalysis
>> [ 98%] Generating core/sip_corepart0.cpp, core/sip_corepart1.cpp,
>> core/sip_corepart2.cpp, core/sip_corepart3.cpp
>> Scanning dependencies of target python_module_qgis__core
>> module_qgis__core.dir/core/sip_corepart0.cpp.o
>> module_qgis__core.dir/core/sip_corepart1.cpp.o
>> module_qgis__core.dir/core/sip_corepart2.cpp.o
>> module_qgis__core.dir/core/sip_corepart3.cpp.o
>> Linking CXX shared library ../output/python/qgis/_core.so
>> [ 98%] Built target python_module_qgis__core
>> [ 98%] Built target pycore
>> [ 98%] Generating gui/sip_guipart0.cpp, gui/sip_guipart1.cpp,
>> gui/sip_guipart2.cpp, gui/sip_guipart3.cpp
>> sip: Unable to find file "Qsci/qscimod4.sip"
>> make[2]: *** [python/gui/sip_guipart0.cpp] Error 1
>> make[1]: *** [python/CMakeFiles/python_module_qgis__gui.dir/all] Error 2
>> make: *** [all] Error 2
>> I'm on Ubuntu 14.04.
>> Regards
>> Stefan
>> Freundliche Grüsse
>> Stefan Ziegler
>> Kantonsgeometer
>> Amt für Geoinformation
>> Amtliche Vermessung
>> Rötistrasse 4
>> 4500 Solothurn
>> Telefon +41 32 627 75 96
>> Telefax +41 32 627 75 98
>> stefan.ziegler at bd.so.ch
>> http://www.so.ch
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140722/e7267ccd/attachment-0001.html>
