[Qgis-developer] Project temp file archive bit.
G. Garibaldi digitalmaps at cox.net
Wed Jul 23 10:20:56 PDT 2014
For some reason a project temp file or a backup file using the extension
.qgs~ is showing up in my projects directory with QGIS 2.4 Win 7 64 bit.
The "xcopy *.qgs" command I use for archival purposes is catching the
.qgs~ file as well. This behavior is different from every QGIS version
up to at least 2.18 that I have used, for at least the last 5 years. Why
has this changed? Could it be put back like it was? Does anybody have a
workaround? Is there a switch somewhere to put the temp file in another
subdirectory (I did a casual search for this but couldn't find one)?
On 7/23/2014 7:46 AM, G. Garibaldi wrote:
> The behavior of the project temp file has changed with 2.4. The
> archive bit is being set. Could you please turn the archive bit off?
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140723/20556e3c/attachment.html>
