[Qgis-developer] cmake configure error
Larry Shaffer larrys at dakotacarto.com
Fri Jul 25 11:04:02 PDT 2014
On Thu, Jul 24, 2014 at 1:57 AM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Hi Jürgen
> On 24.07.2014 09:51, Jürgen E. Fischer wrote:
> > Hi Matthias,
> > On Thu, 24. Jul 2014 at 09:37:59 +0200, Matthias Kuhn wrote:
> >> Same here, clean rebuild does not help.
> > Odd, as it did here.  And the nightly builds[1] apparently didn't have a
> > problem with 9a10b79 either.
> Thanks for the answer. I checked again. Starting from scratch in  a new
> build dir it cmake's correctly.
> Manually deleting QSCINTILLA_INCLUDE_DIR from the cmake cache (e.g. in
> ccmake) fixes things as well, while a simple 'make clean' was not enough.
Confirmed here on Mac, for the OS X 10.6 nightly. I just trashed the
CMakeCache.txt file and then the build worked fine, after reinitializing
the cache.
Regards,
Larry
> Regards
> Matthias
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140725/8fa3aee5/attachment.html>
