[Qgis-developer] Use Georeferencer Core-Plugin with python
Olivier Dalang olivier.dalang at gmail.com
Tue Jul 29 03:12:06 PDT 2014
Hi Felix,
Any progress on this ?
I've also a case where I'd love to be able to use georeferencer with
python...
Thanks !
Olivier Dalang
Digital Humanities Lab (DHLAB) - http://dhlab.epfl.ch
EPFL CDH DHLAB  / CM 2 271
Station 10 / CH-1015 Lausanne
Tel. +41 21 693 02 46
2014-05-19 22:07 GMT+02:00 Felix Schmidt <felix.schmidt at uni-weimar.de>:
> Thanks a lot for the support,
> i will read your commit and talk to my team mates on Wednesday.
> Felix
> Am 19.05.2014 21:09, schrieb Matthias Kuhn:
>  A pull request is online for review:
>> https://github.com/qgis/QGIS/pull/1370
>> Please post your comments there if you are interested in this
>> functionality.
>> On Mon 19 Mai 2014 18:55:54 CEST, G. Allegri wrote:
>>> Of course Matthias is right if you want to interface with a plugin
>>> instance running inside QGIS. That's why I said you could bind only
>>> the inner logic of the Georeferencer to use it "outside" the plugin
>>> instance. In case you need to control, or get work done from, the
>>> Georeferencer plugin itself you have to do what Matthias is doing in
>>> its commit.
>>> giovanni
>>> 2014-05-19 18:33 GMT+02:00 Matthias Kuhn <matthias.kuhn at gmx.ch
>>> <mailto:matthias.kuhn at gmx.ch>>:
>>>      The python modules gui and core are exported and the "iface"
>>>      variable (QgisInterface) knows about their presence. But
>>>      QgisInterface should not have any dependencies on plugin code,
>>>      therefore it's harder to access this code.
>>>      It may not be hard if you only make use of code which you use in a
>>>      standalone library way (maybe that would already be enough for
>>>      your case). If you want to get access to a running plugin instance
>>>      this is a different story. You can have a look at the code in [1]
>>>      for an example of how this might be accomplished. Although the
>>>      code seems not to be working, I've got to check what's still
>>>      missing there, but in principle the ideas in commit [1] should work.
>>>      Best,
>>>      Matthias
>>>      [1]
>>>      https://github.com/m-kuhn/__QGIS/commit/__
>>> 571b4fa7e6afcefb9c4911339db2c4__b7689ce6a9
>>>      <https://github.com/m-kuhn/QGIS/commit/
>>> 571b4fa7e6afcefb9c4911339db2c4b7689ce6a9>
>>>      On Mon 19 May 2014 05:34:41 PM CEST, Felix Schmidt wrote:
>>>          @Matthias: what do you mean with:
>>>          Am 19.05.2014 16:41, schrieb Matthias Kuhn: "the code is not
>>>          exported
>>>          to the gui or core libraries/sip modules"?
>>>              It will not be so easy to just write wrappers because the
>>>              code is not
>>>              exported to the gui or core libraries/sip modules.
>>>              I have written code that makes it possible to generate
>>> python
>>>              bindings for (C++) plugins and I'm considering creating a
>>>              pull-request for it.
>>>              Matthias
>>>              On 05/19/2014 04:33 PM, G. Allegri wrote:
>>>                  It depends on what parts of the Georeferencer you
>>>                  need. If you don't
>>>                  need the GUI but only the math, you could consider
>>>                  writing a SIP
>>>                  wrapper around QgsGeorefTransformInterface
>>>                  implementations [1].
>>>                  Otherwise, if Python performance would suffice, you
>>>                  could grab the
>>>                  low level math from QgsGeorefTransform and
>>>                  QgsLeastSquares [2] and
>>>                  translate it to Python.
>>>                  giovanni
>>>                  [1]
>>>                  https://github.com/qgis/QGIS/_
>>> _blob/master/src/plugins/__georeferencer/__qgsgeoreftransform.cpp
>>>                  <https://github.com/qgis/QGIS/blob/master/src/plugins/
>>> georeferencer/qgsgeoreftransform.cpp>
>>>                  [2]
>>> _blob/master/src/plugins/__georeferencer/qgsleastsquares.__cpp
>>> georeferencer/qgsleastsquares.cpp>
>>>                  2014-05-19 16:32 GMT+02:00 G. Allegri
>>>                  <giohappy at gmail.com <mailto:giohappy at gmail.com>
>>>                  <mailto:giohappy at gmail.com <mailto:giohappy at gmail.com
>>>                  need. If you
>>>                      don't need the GUI but only the math, you could
>>>                  consider writing
>>>                      a SIP wrapper around QgsGeorefTransformInterface
>>>                  implementations
>>>                      [1].
>>>                  you could grab
>>>                      the low level math from QgsGeorefTransform and
>>>                  QgsLeastSquares
>>>                      [2] and translate it to Python.
>>>                      giovanni
>>>                      [1]
>>>                      [2]
>>>                      2014-05-19 16:10 GMT+02:00 Felix Schmidt
>>>                  <mailto:felix.schmidt at uni-weimar.de>
>>>                  <mailto:felix.schmidt at uni-__weimar.de
>>>                  <mailto:felix.schmidt at uni-weimar.de>>>:
>>>                          Hello Giovanni,
>>>                          thanks for your answer. Do you think it is
>>>                  easier to write
>>>                          the Plugin for the historical border
>>>                  extraction in c++
>>>                          instead of python, cause of the binding
>>>                  implementation?
>>>                          Felix
>>>                          Am 19.05.2014 14:52, schrieb G. Allegri:
>>>                              Hi Felix,
>>>                              I fear you will have to write your own
>>>                  bindings if you
>>>                              want to leavarage the Georeferencer plugin
>>>                  code. It's a
>>>                              plugin, so it's functionality isn't
>>>                  exposed through QGIS
>>>                              API.
>>>                      Giovanni Allegri
>>>                      http://about.me/__giovanniallegri
>>>                  <http://about.me/giovanniallegri>
>>>                      Twitter: https://twitter.com/_giohappy_
>>>                      blog: http://blog.spaziogis.it
>>>                      GEO+ geomatica in Italia http://bit.ly/GEOplus
>>>                  Giovanni Allegri
>>>                  _________________________________________________
>>>                  Qgis-developer mailing list
>>>                  Qgis-developer at lists.osgeo.org
>>>                  <mailto:Qgis-developer at lists.osgeo.org>
>>>                  http://lists.osgeo.org/__mailman/listinfo/qgis-__
>>> developer
>>>                  <http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>      Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.
>>> osgeo.org>
>>>      http://lists.osgeo.org/__mailman/listinfo/qgis-__developer
>>>      <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>> Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140729/6638f2e4/attachment-0001.html>
