[Qgis-developer] labelling issues
Alexandre Neto senhor.neto at gmail.com
Wed Jun 4 03:05:44 PDT 2014
*) I'm not able to find what is the proper postgis datatype to be used
for data defined position of labels, I tested the one available wit
the qgis gui and then labels stop to render (is ok with shapefile
"decimal" data type).
Maybe this is something related to this issue?
https://hub.qgis.org/issues/9148
Because of this problem I found that using charvar in Postgis works better
than numeric fields.
Best regards,
Alexandre Neto
On Wed, Jun 4, 2014 at 10:59 AM, Régis Haubourg <
regis.haubourg at eau-adour-garonne.fr> wrote:
> Giovanni Manghi-2 wrote
> > *) data defined rotation works, but then the label "rotate tool" does
> > not work (does nothing)
> Well,
> what I have here is
> - data defined rotation does work only if XY data is not null. Rotation
> tools works only on moved labels too.
> Régis
> http://osgeo-org.1560.x6.nabble.com/labelling-issues-tp5143956p5143967.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140604/7603f32b/attachment.html>
