[Qgis-developer] Legend tree appears expanded, not closed in master
Andreas Neumann a.neumann at carto.net
Fri Jun 13 05:32:53 PDT 2014
Hi Martin,
I confirm that it works now as expected. Thank you for the fix!
Andreas
Am 13.06.2014 10:25, schrieb Martin Dobias:
> Hi Andreas
> On Tue, Jun 10, 2014 at 9:49 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> I noticed that a project that had the layer tree in a closed state in
>> QGIS 2.2 appears expanded in QGIS master. In this project I have several
>> nested groups (up to 3 levels deep). The first two levels appear
>> I would prefer if the groups would appear in a closed state as in
>> version 2.2.
>> This is probably a side-effect of the legend tree redesign? Is this a
>> known bug and can it be fixed?
> Thanks for reporting that - there was a small bug when reading older
> project files. It is fixed in 9af0b3
> Regards
> Martin
