[Qgis-developer] Datum Transformation - parameters for mainland Portugal
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Jun 18 23:00:33 PDT 2014
Hi Pedro
QGIS imports the towgs84 transformations from GDAL and adds a list of
ntv2 transformations into srs.db.
So I'm going to add/modify the ntv2 transformations (if there are no
objections from other portuguese users). For the towgs84 ones I agree
with Andre that it is better to bring it to gdal/epsg level.
Regards,
Marco
On 18.06.2014 16:59, Andre Joost wrote:
> Hi Pedro,
> Am 18.06.2014 15:13, schrieb Pedro Venâncio:
>> I have an update to the parameters that are in Datum Transformation
>> for mainland Portugal.
>> After an analysis of the parameters that are currently inserted in
>> srs.db, I think we should keep only the latest parameters that are
>> provided by the Portuguese Surveying Authority (Directorate-General
>> of the Territory), to avoid confusion among users.
>> So, we should keep only the transformation parameters of Molodensky,
>> Bursa-Wolf, and two grids NTv2 that are in use here in Portugal, one
>> from the Directorate-General of the Territory, and another from the
>> University of Porto.
> it has little use to change the parameters in QGIS only.
> All applications that use GDAL/PROJ use the same database of CRS. This
> is kept in sync with the official EPSG database at
> <http://www.epsg-registry.org/>
> The EPSG database offers different transformations from local datums
> to WGS84. One of these is usually bundled to the coordinate system
> when you use QGIS/GDAL/PROJ. Other software like ARCGIS keeps
> coordinate systems and datum transformations separated.
> Latest versions of QGIS allow to use a different datum transformation,
> but keep in mind that software that stores only EPSG codes (like
> spatialite) will use nethertheless the default datum transformation.
> If you feel uncomfortable with the default datum transformation, and
> you have "official" sources, you might open a ticket for the CRS
> databases used in GDAL and PROJ. The parameters should be at least in
> the EPSG database.
> QGIS syncs with that database after installation to avoid
> discrepancies on your own computer.
> Greetings,
> André Joost
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
