[Qgis-developer] QGIS Server: using same layer name in different projects
Luca Manganelli luca76 at gmail.com
Thu Jun 19 07:03:03 PDT 2014
On Thu, Jun 19, 2014 at 10:12 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Luca,
> It is a known issue.
> It is not an issue about the layer name, but of layer ids. You have to
> make sure that layer ids in all of your projects are unique.
> You probably copy/pasted projects and this does not upgrade the layerid.
> It is not a problem to have two or more identical layer names, but the
> layer ids have to be unique.
> I agree that this is suboptimal and should be resolved in an upcoming
> version. The layercache should have both the project name and the
> layerid to form a unique identifier from both attributes.
> Someone needs to either work on it or found this improvement.
Thank you, it fixed my problem! :-)
