[Qgis-developer] qgis-server will crash on a specific project
Andrea Peri aperi2007 at gmail.com
Sun Jun 22 05:01:52 PDT 2014
Hi Marco, other information:
The
MAX_CACHE_LAYERS workarund
Now seem do not work anymore.
2014-06-22 13:48 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I tested it but don't seem work.
> I'm using the master, is that ?
> A.
> 2014-06-22 13:04 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>> It should work now. Could you test with the current git version? My test
>> projects are not large enough.
>> Regards,
>> Marco
>> On 22.06.2014 12:27, Andrea Peri wrote:
>>> you have right,
>>> it is not a good solution. Too project depending and resource consuming.
>>> thx for a better fixing
>>> A.
>>> 2014-06-22 12:15 GMT+02:00 Marco Hugentobler
>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
>>>> This is a short-time workaround for users.
>>>> Regards,
>>>> Marco
>>>> On 22.06.2014 12:12, Andrea Peri wrote:
>>>>> Hi,
>>>>> thx for response.
>>>>> meanwhile,
>>>>> I notice that the max allowed layers is exactly 101.
>>>>> This mean (knowing C/C++) an array of 100 elements.
>>>>> Searching for this particular value,
>>>>> i find in the file "mapserver/qgsmslayercache.cpp"
>>>>> is defined
>>>>>           mDefaultMaxLayers = 100;
>>>>> if not defined the environment variable "MAX_CACHE_LAYERS"
>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>>>>>     if ( maxLayerEnv )
>>>>> So a possible solution could be to set this environment variable.
>>>>> I try and report.
>>>>> Regards,
>>>>> Andrea.
>>>>> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler
>>>>>> It is a problem with the layer cache. Will provide a fix for that soon.
>>>>>> Regards,
>>>>>> Marco
>>>>>> On 22.06.2014 11:49, Andrea Peri wrote:
>>>>>>> Hi,
>>>>>>> I confirm.
>>>>>>> There is a layer limit in QGIS-Server
>>>>>>> I do a huge test removing one by one all the layers from my project.
>>>>>>> And after the removing of every single layer I retest the working.
>>>>>>> Aftr a while of time. I reach the limit.
>>>>>>> And the project begin to run.
>>>>>>> I do other test to exclude that was the number of layer inside a
>>>>>>> single
>>>>>>> group.
>>>>>>> All the test give the response that seem to be the max number of
>>>>>>> layers in a project.
>>>>>>> So the question is:
>>>>>>> QGIS desktop allow to put more layers rather than how many are
>>>>>>> accepted from qgis-server.
>>>>>>> This not good for a WYSIWYG system.
>>>>>>> Ok, I will try to patch my server when found exactly where is the
>>>>>>> problem.
>>>>>>> Meanwhile,
>>>>>>> Now the question is on what structure is this limit ?
>>>>>>> I don't guess it is simply a layer limit but perhaps a more specific
>>>>>>> structure.
>>>>>>> Now I have a project that crash , and a project with a one less layer
>>>>>>> that
>>>>>>> work.
>>>>>>> Doing a DIFF beetween the two projects I see the possible structure
>>>>>>> breakable are:
>>>>>>> layer-tree-canvas -> custom-order -> item
>>>>>>> maplayer
>>>>>>> Digitizing -> LayerSnappingList -> value   (type QStringList)
>>>>>>> Digitizing -> LayerSnappingEnabledList -> value   (type QStringList)
>>>>>>> Digitizing -> LayerSnapToList -> value   (type QStringList)
>>>>>>> Digitizing -> LayerSnappingToleranceList -> value   (type QStringList)
>>>>>>> I check if in the code there is a limited array dimension for this
>>>>>>> objects.
>>>>>>> Regards,
>>>>>>> Andrea.
>>>>>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>> Hi,
>>>>>>>> I do some other tests.
>>>>>>>> I take my project that give QG crash and split it in two compementary
>>>>>>>> projects.
>>>>>>>> Of course I do this using qgis desktop to avoid unvolontary errors.
>>>>>>>> Testing both of them on QS there is no crash !
>>>>>>>> So:
>>>>>>>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>>>>>>>> to the number of Groups or Layers it can have in a project.
>>>>>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>>>>>> Is this a plausible theory ?
>>>>>>>> Thx,
>>>>>>>> Andrea.
>>>>>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>> Hi,
>>>>>>>>> I have a qgis-server that will crash on a specific project.
>>>>>>>>> The qgis-server will run correctly with another project that seem
>>>>>>>>> almost similar (both use the SVG symbols).
>>>>>>>>> The project that crash my QG  run correctly and smootly on a qgis
>>>>>>>>> desktop (qgis-dev) on a windows system.
>>>>>>>>> The project use SVG symbols, but also the other project I test on
>>>>>>>>> QSused SVG symbol
>>>>>>>>> so I suppose the SVG engine is ok.
>>>>>>>>> Also I check t have set correctly the SVG paths.
>>>>>>>>> Also I update to the very last (about 4 hours ago) master version.
>>>>>>>>> After all this check the qgis-server still crash.
>>>>>>>>> So I try to set the logfile, but the log is always empty.
>>>>>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>>>>>> So I set an environment shell to run it manually and to test the cgi
>>>>>>>>> with a gdb session.
>>>>>>>>> The results are this:
>>>>>>>>> [Thread debugging using libthread_db enabled]
>>>>>>>>> Using host libthread_db library
>>>>>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>>>>>       from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>>>>>> (gdb)
>>>>>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>>>>>> But another project will run without any apparent problem.
>>>>>>>>> Many thx for every hint.
>>>>>>>>> Andrea Peri
>>>>>>>>> qwerty àèìòù
>>>>>>>> Andrea Peri
>>>>>>>> qwerty àèìòù
>>>>>> Dr. Marco Hugentobler
>>>>>> Sourcepole -  Linux & Open Source Solutions
>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
