[Qgis-developer] QGIS Crash - Serious problem in 2x
Ted tiruchirapalli at gmail.com
Mon Jun 23 16:30:12 PDT 2014
forgot,
using Windows OS
Win 7 Professional x64
Thanks
Ted
On Tue, Jun 24, 2014 at 7:27 AM, Ted <tiruchirapalli at gmail.com> wrote:
> Hi Developers
> Encountered a very serious problem, looks like this issue is there in 2.x
> Ways to reproduce;
> 1. Add a world boundary shp file in wgs84 (you can use other files too)
> http://thematicmapping.org/downloads/world_borders.php
> 2. Open the print composer, add a new map
> 3. add scale bar
> 4. close the composer, return back
> 5 remove the layer from layer list
> 6. boom, qgis crash
> hope you can fix this soon, thanks
> The scale bar issue
> 1. When a file is degree (wgs84), the scale-bar in print composer is
> useless since its trying to use the map unit.
> 2. Its logical that, in map composer its always linear map unit as in
> meter, feet, km, etc
> 3. using qgis in schools and this pose a serious issue, since the users
> dont understand projection etc.
> 4. the expected behavior is, immaterial of underlying projection the
> scale-bar should have the option to use linear map unit, specially meters,
> km, mile
> 5. read in stackexchange, this is a known issue. hope the dev community
> can help to fix this one.
> thanks a lot.
> hurt my fingers, not able to type proper :(
> cheers
> ted
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140624/0ef8e2ce/attachment.html>
