[Qgis-developer] error building qgis debian package for 2.2
Etienne Tourigny etourigny.dev at gmail.com
Wed Mar 5 17:05:49 PST 2014
I am trying to build debian packages for 2.2 in Ubuntu Raring (12.04) but
there seems to be a problem with libspatialindex, although I do have
libspatialindex1 and libspatialindex-dev installed
The build process complains about missing /libspatialindex.so which is in
/usr/lib/
$ dpkg-buildpackage
[ 12%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/moc_qextserialenumerator.cxx.o
cd /data/src/qgis/qgis-master/debian/build/src/core && /usr/bin/c++
-DEXTERNAL_SPATIALITE -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB
-DQT_NO_CAST_TO_ASCII -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_SQL_LIB
-DQT_SVG_LIB -DQT_TEST_LIB -DQT_WEBKIT_LIB -DQT_XML_LIB -D_HAVE_PTHREAD_
-D_TTY_POSIX_ -Dqgis_core_EXPORTS -g -O2 -fstack-protector
--param=ssp-buffer-size=4 -Wformat -Werror=format-security
-D_FORTIFY_SOURCE=2 -O2  -Wall -Wextra -Wno-long-long -Wformat-security
-Wno-strict-aliasing -fPIC -I/usr/include/qt4 -I/usr/include/qt4/QtOpenGL
-I/usr/include/qt4/QtSvg -I/usr/include/qt4/QtWebKit
-I/usr/include/qt4/QtGui -I/usr/include/qt4/QtTest -I/usr/include/qt4/QtXml
-I/usr/include/qt4/QtSql -I/usr/include/qt4/QtNetwork
-I/usr/include/qt4/QtCore -I/data/src/qgis/qgis-master/debian/build
-I/data/src/qgis/qgis-master/src/core
-I/data/src/qgis/qgis-master/src/core/composer
-I/data/src/qgis/qgis-master/src/core/dxf
-I/data/src/qgis/qgis-master/src/core/pal
-I/data/src/qgis/qgis-master/src/core/raster
-I/data/src/qgis/qgis-master/src/core/renderer
-I/data/src/qgis/qgis-master/src/core/symbology-ng
-I/data/src/qgis/qgis-master/src/core/gps/qextserialport
-I/usr/include/spatialindex -I/usr/include/gdal    -DCORE_EXPORT=
-DGUI_EXPORT= -DPYTHON_EXPORT= -DANALYSIS_EXPORT= -DAPP_EXPORT=
-DTEST_DATA_DIR="\"/data/src/qgis/qgis-master/tests/testdata\"" -o
-c
/data/src/qgis/qgis-master/debian/build/src/core/gps/qextserialport/moc_qextserialenumerator.cxx
make[3]: *** No rule to make target
`/usr/lib/x86_64-linux-gnu/libspatialindex.so', needed by
`output/lib/libqgis_core.so.2.2.0'.  Stop.
make[3]: Leaving directory `/data/src/qgis/qgis-master/debian/build'
make[2]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make[2]: Leaving directory `/data/src/qgis/qgis-master/debian/build'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/data/src/qgis/qgis-master/debian/build'
make: *** [build-stamp] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140305/7392ada6/attachment.html>
