[Qgis-developer] error starting qgis (built from source)
Yves Jacolin yjacolin at free.fr
Mon May 5 10:32:54 PDT 2014
ok I understand :)
Add /home/chrismarx/apps/lib/ in the /etc/ld.so.conf.d/qgis.conf is not
already done and run sudo ldconfig.
If you already do such command line, well I don't know what's wrong. Last
idea: do you use redhat or something like this?
Y.
Le lundi 5 mai 2014, 13:21:44 chris marx a écrit :
> Yay! Ok, that did it. So, did I do something wrong? After running updatedb,
> locate found the libraries in "/home/chrismarx/apps/lib/" . According to
> the build instructions, it suggested to create :
> mkdir -p ${HOME}/apps
> and build the app into there. Is that where those libraries should have
> ended up?
> On Mon, May 5, 2014 at 12:50 PM, Yves Jacolin <yjacolin at free.fr> wrote:
> > Le lundi 5 mai 2014, 10:26:34 chris marx a écrit :
> > > Hi,
> > >  Ok, some of this is a bit unfamiliar for me, but here goes. So, I ran
> > ldd
> > > on the qgis app, and it very clearly shows that that libqgis_core was
> > > not
> > > found:
> > > chrismarx at ubuntu:~/apps/bin$ ldd ./qgis
> > >     linux-vdso.so.1 =>  (0x00007fff12158000)
> > >     libqwt-qt4.so.5 => /usr/lib/libqwt-qt4.so.5 (0x00007f7b3606f000)
> > >     libQtSql.so.4 => /usr/lib/x86_64-linux-gnu/libQtSql.so.4
> > > (0x00007f7b35e30000)
> > >     libQtWebKit.so.4 => /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4
> > > (0x00007f7b34077000)
> > >     libgdal1.7.0.so.1 => /usr/lib/libgdal1.7.0.so.1 (0x00007f7b3366d000)
> > >     libqgis_core.so.2.3.0 => not found
> > >     libqgis_gui.so.2.3.0 => not found
> > >     libqgis_analysis.so.2.3.0 => not found
> > This is the problem, if you added your correct lib path in
> > /etc/ld.so.conf.d/qgis.conf (filename is not important, only the extension
> > is
> > important) then run sudo ldconfig your system should find them.
> > First, run sudo updatedb then wait for a while. Finaly check the location
> > with:
> > locate libqgis_gui.so.2.3.0
> > It gives you at least two location: your build src and your lib install
> > path.
> > Take the second one and put it into /etc/ ld.so.conf.d/qgis.conf, run
> > again
> > sudo ldconfig
> > check again with your ldd command.
> > Y.
> > Yves Jacolin
Yves Jacolin
